> I faced the following error message when building 'areaDetector'. I think the three red lines in CONFIG_SITE.local can make difference.
I suspect you also have a CONFIG_SITE.local.linux-x86_64 file that is defining WITH_BOOST=YES. Is that true? If so that file takes precedence over CONFIG_SITE.local.
If that is not the case then please send the complete error message. What you have sent is not enough to figure out what went wrong.
From: Tech-talk <[email protected]> on behalf of Jong Woo Kim via Tech-talk <[email protected]>
Sent: Tuesday, March 3, 2020 6:37 PM
To: [email protected]
Subject: errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9
Hi~
But they do not influence at all. No matter what the variables have, (YES or NO) the following error message always came out.
If you suggest any ideas, it would be appreciated.
EPICS base-7.0.3.1
asyn4-37
areaDetector-R3-9
ADCore-R3-9
__________________________________________________________________
compilation terminated.
make[4]: *** [AsynPortClientContainer.o] Error 1
make[4]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp/pluginTests/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp/pluginTests'
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore'
make: *** [/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore.install] Error 2
# BOOST is required for the ADCore/pluginTests unit tests
WITH_BOOST = NO
BOOST_EXTERNAL = YES
#BOOST_LIB =
#BOOST_INCLUDE =
# Uncomment this line if you want to use STATIC Linking when building
# ADCore/pluginTests unit tests.
#BOOST_USE_STATIC_LINK = YES
- errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9 Jong Woo Kim via Tech-talk
Quantalux sCMOS camera Miceli, Antonino via Tech-talk
Re: Quantalux sCMOS camera Mark Rivers via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
