Subject: errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9
From: Jong Woo Kim via Tech-talk <[email protected]>
Date: Wed, 4 Mar 2020 00:37:30 +0000
Hi~
I faced the following error message when building 'areaDetector'. I think the three red lines in CONFIG_SITE.local can make difference.
But they do not influence at all. No matter what the variables have, (YES or NO) the following error message always came out.
If you suggest any ideas, it would be appreciated.
EPICS base-7.0.3.1
asyn4-37
areaDetector-R3-9
ADCore-R3-9
__________________________________________________________________
compilation terminated.
make[4]: *** [AsynPortClientContainer.o] Error 1
make[4]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp/pluginTests/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp/pluginTests'
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore'
make: *** [/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore.install] Error 2
# BOOST is required for the ADCore/pluginTests unit tests
WITH_BOOST     = NO
BOOST_EXTERNAL = YES
#BOOST_LIB     =
#BOOST_INCLUDE =
# Uncomment this line if you want to use STATIC Linking when building
# ADCore/pluginTests unit tests.
#BOOST_USE_STATIC_LINK = YES
Re: errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9 Mark Rivers via Tech-talk
Prev: areaDetector ADViewers R1-6 released Mark Rivers via Tech-talk
Next: Quantalux sCMOS camera Miceli, Antonino via Tech-talk
Next: Re: errors in /ADCore/ADApp/pluginTests when building areaDetector-R3-9 Mark Rivers via Tech-talk
