1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: camserver/NDStdArray latency mystery
To: 'John Dobbins' <[email protected]>
Date: Tue, 10 Mar 2020 16:49:22 +0000
Hi John,
Here is what is supposed to happen:
1)      You press Acquire
2)      ADPilatus sends a message to camserver to collect an image
3)      camserver collects an image and writes a file
4)      ADPilatus reads the file that camserver just wrote into an NDArray
5)      ADPilatus calls the NDPluginStdArrays plugin with that NDArray
6)      The Channel Access client receives the array and displays it
Can you define what you mean by “latency”?  Do you mean that the Channel Access client is displaying the previous image, not the one that was just collected?  If you open the file that camserver wrote is it correct?
Are there any messages on the IOC console?
Is the IOC running on the same machine as camserver?  If not, are their clocks well synchronized?  There is time-stamp checking on the files as ADPilatus reads them to make sure it is not reading an “old” file, but rather one that was just written.
Can you turn on asynTrace debugging in ADPilatus to see what is going on?
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, March 10, 2020 11:38 AM
To: [email protected]
Subject: camserver/NDStdArray latency mystery
First, apologies because this is about two old versions of areaDetector.
We have two Pilatus IOCs. One is areaDetector R1-9, Base 3.14.8 and one is R2-2 Base 3.14.12.4
Taking single images on the R2-2 version there is a latency of one image in the NDStdArray which is sent to Channel Access.  The image is also being written to a file and that receives the latest image however the file is being written by camserver (tvx-7.3.13-121212).  Note that these are manually triggered images, rate is not an issue.
It is possible that the IOC is received a delayed image from camserver.
How can I determine if the latency is between camserver/IOC  or  within IOC?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: camserver/NDStdArray latency mystery John Dobbins via Tech-talk
Prev: camserver/NDStdArray latency mystery John Dobbins via Tech-talk
Next: Re: camserver/NDStdArray latency mystery John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
