Subject: Re: camserver/NDStdArray latency mystery
From: John Dobbins via Tech-talk <[email protected]>
Date: Tue, 10 Mar 2020 18:11:47 +0000
Mark,
Thanks for taking the time to read and reply. As soon as I saw your mention of 'clock' bells went off.  In my new position I have inherited a number of detector/computers pairs.  Many are not configured with ntp and may go long periods of time without their clock being set.
As soon I set the correct time everything was copacetic.
Again, thanks for your indulgence.
John
Sent: Tuesday, March 10, 2020 12:49 PM
To: John Dobbins <[email protected]>
Subject: RE: camserver/NDStdArray latency mystery
Hi John,
Here is what is supposed to happen:
1)      You press Acquire
2)      ADPilatus sends a message to camserver to collect an image
3)      camserver collects an image and writes a file
4)      ADPilatus reads the file that camserver just wrote into an NDArray
5)      ADPilatus calls the NDPluginStdArrays plugin with that NDArray
6)      The Channel Access client receives the array and displays it
Can you define what you mean by “latency”?  Do you mean that the Channel Access client is displaying the previous image, not the one that was just collected?  If you open the file that camserver wrote is it correct?
Are there any messages on the IOC console?
Is the IOC running on the same machine as camserver?  If not, are their clocks well synchronized?  There is time-stamp checking on the files as ADPilatus reads them to make sure it is not reading an “old” file, but rather one that was just written.
Can you turn on asynTrace debugging in ADPilatus to see what is going on?
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, March 10, 2020 11:38 AM
To: [email protected]
Subject: camserver/NDStdArray latency mystery
First, apologies because this is about two old versions of areaDetector.
We have two Pilatus IOCs. One is areaDetector R1-9, Base 3.14.8 and one is R2-2 Base 3.14.12.4
Taking single images on the R2-2 version there is a latency of one image in the NDStdArray which is sent to Channel Access.  The image is also being written to a file and that receives the latest image however the file is being written by camserver (tvx-7.3.13-121212).  Note that these are manually triggered images, rate is not an issue.
It is possible that the IOC is received a delayed image from camserver.
How can I determine if the latency is between camserver/IOC  or  within IOC?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
camserver/NDStdArray latency mystery John Dobbins via Tech-talk
RE: camserver/NDStdArray latency mystery Mark Rivers via Tech-talk
Prev: RE: camserver/NDStdArray latency mystery Mark Rivers via Tech-talk
Next: AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
Next: vxW shell related Stefen Paul via Tech-talk
