Subject: How can I add multiple serial ports in a single IOC?
To: tech-talk <[email protected]>
Date: Tue, 17 Mar 2020 12:08:26 +0800
Hi everyone,
I want to add 10 or more serial ports in a single IOC. All the serial ports have the same configuration besides the serial port name.
The single port configuration is like this:
        drvAsynSerialPortConfigure ("PS1","/dev/ttyS1")
        asynSetOption ("PS1", 0, "baud", "9600")
        asynSetOption ("PS1", 0, "bits", "8")
        asynSetOption ("PS1", 0, "parity", "none")
        asynSetOption ("PS1", 0, "stop", "1")
        asynSetOption ("PS1", 0, "clocal", "Y")
        asynSetOption ("PS1", 0, "crtscts", "N")
if I want to add 10 serial ports, should I add them one by one and repeat the above statements 10 times? Is there any simple method? Can  I  add the serial ports as a group,which has the same configuration?  I didn't find any document about this.
Thank you very much for your help.
Best Regards
Chunxia  Yin
2020-3-17
Prev: Re: [EXTERNAL] Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Kasemir, Kay via Tech-talk
Next: Re: write to a single element of an array field Ben Franksen via Tech-talk
Next: Re: How can I add multiple serial ports in a single IOC? Mark Rivers via Tech-talk
