Subject: Re: How can I add multiple serial ports in a single IOC?
Date: Tue, 17 Mar 2020 12:16:50 +0000
> if I want to add 10 serial ports, should I add them one by one and repeat the above statements 10 times? Is there any simple method?
> Can  I  add the serial ports as a group,which has the same configuration?  I didn't find any document about this.
You could make another script called, for example addSerialPort.  It would look like this:
        drvAsynSerialPortConfigure ("$(PORT)","$(DEVICE)")
        asynSetOption ("$(PORT)", 0, "baud", "9600")
        asynSetOption ("$(PORT)", 0, "bits", "8")
        asynSetOption ("$(PORT)", 0, "parity", "none")
        asynSetOption ("$(PORT)", 0, "stop", "1")
        asynSetOption ("$(PORT)", 0, "clocal", "Y")
        asynSetOption ("$(PORT)", 0, "crtscts", "N")
Then you would set 2 environment variables and call the script:
epicsEnvSet("PORT", "PS1")
epicsEnvSet("DEVICE", " /dev/ttyS1")
< addSerialPort
epicsEnvSet("PORT", "PS2")
epicsEnvSet("DEVICE", " /dev/ttyS2")
< addSerialPort
Then you only need 3 lines per port rather than 7.
From: Tech-talk <[email protected]> on behalf of yincx--- via Tech-talk <[email protected]>
Sent: Monday, March 16, 2020 11:08 PM
To: tech-talk
Subject: How can I add multiple serial ports in a single IOC?
Hi everyone,
I want to add 10 or more serial ports in a single IOC. All the serial ports have the same configuration besides the serial port name.
The single port configuration is like this:
        drvAsynSerialPortConfigure ("PS1","/dev/ttyS1")
        asynSetOption ("PS1", 0, "baud", "9600")
        asynSetOption ("PS1", 0, "bits", "8")
        asynSetOption ("PS1", 0, "parity", "none")
        asynSetOption ("PS1", 0, "stop", "1")
        asynSetOption ("PS1", 0, "clocal", "Y")
        asynSetOption ("PS1", 0, "crtscts", "N")
if I want to add 10 serial ports, should I add them one by one and repeat the above statements 10 times? Is there any simple method? Can  I  add the serial ports as a group,which has the same configuration?  I didn't find any document about this.
Thank you very much for your help.
Best Regards
Chunxia  Yin
2020-3-17
[email protected]
Re: How can I add multiple serial ports in a single IOC? Lang, Keenan C. via Tech-talk
How can I add multiple serial ports in a single IOC? yincx--- via Tech-talk
Prev: Re: write to a single element of an array field Ben Franksen via Tech-talk
Next: caproto-monitor exits when IOC exits too Rute Mendes via Tech-talk
Prev: How can I add multiple serial ports in a single IOC? yincx--- via Tech-talk
Next: Re: How can I add multiple serial ports in a single IOC? Lang, Keenan C. via Tech-talk
