Subject: Re: How can I add multiple serial ports in a single IOC?
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Tue, 17 Mar 2020 15:49:30 +0000
>Then you only need 3 lines per port rather than 7.
With epics base 3.15 or later, you can reduce it to 1. The command 'iocshLoad' runs a given script with a set of temporary environment variables that only exist for the duration of running said script. This has the added benefit of not polluting your global environment, so that if you accidentally forget to set a variable, you get an error message saying that the variable is undefined rather than the previous value bleeding through.
You could thus do
    iocshLoad("./addSerialPort.cmd", "PORT=PS1, DEVICE=/dev/ttyS1")
    iocshLoad("./addSerialPort.cmd", "PORT=PS2, DEVICE=/dev/ttyS2")
Keenan Lang
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Tuesday, March 17, 2020 7:16 AM
To: [email protected] <[email protected]>
> if I want to add 10 serial ports, should I add them one by one and repeat the above statements 10 times? Is there any simple method?
> Can  I  add the serial ports as a group,which has the same configuration?  I didn't find any document about this.
You could make another script called, for example addSerialPort.  It would look like this:
        drvAsynSerialPortConfigure ("$(PORT)","$(DEVICE)")
        asynSetOption ("$(PORT)", 0, "baud", "9600")
        asynSetOption ("$(PORT)", 0, "bits", "8")
        asynSetOption ("$(PORT)", 0, "parity", "none")
        asynSetOption ("$(PORT)", 0, "stop", "1")
        asynSetOption ("$(PORT)", 0, "clocal", "Y")
        asynSetOption ("$(PORT)", 0, "crtscts", "N")
Then you would set 2 environment variables and call the script:
epicsEnvSet("PORT", "PS1")
epicsEnvSet("DEVICE", " /dev/ttyS1")
< addSerialPort
epicsEnvSet("PORT", "PS2")
epicsEnvSet("DEVICE", " /dev/ttyS2")
< addSerialPort
From: Tech-talk <[email protected]> on behalf of yincx--- via Tech-talk <[email protected]>
Sent: Monday, March 16, 2020 11:08 PM
To: tech-talk
Subject: How can I add multiple serial ports in a single IOC?
Hi everyone,
I want to add 10 or more serial ports in a single IOC. All the serial ports have the same configuration besides the serial port name.
The single port configuration is like this:
        drvAsynSerialPortConfigure ("PS1","/dev/ttyS1")
        asynSetOption ("PS1", 0, "baud", "9600")
        asynSetOption ("PS1", 0, "bits", "8")
        asynSetOption ("PS1", 0, "parity", "none")
        asynSetOption ("PS1", 0, "stop", "1")
        asynSetOption ("PS1", 0, "clocal", "Y")
        asynSetOption ("PS1", 0, "crtscts", "N")
if I want to add 10 serial ports, should I add them one by one and repeat the above statements 10 times? Is there any simple method? Can  I  add the serial ports as a group,which has the same configuration?  I didn't find any document about this.
Thank you very much for your help.
Best Regards
Chunxia  Yin
2020-3-17
[email protected]
How can I add multiple serial ports in a single IOC? yincx--- via Tech-talk
Re: How can I add multiple serial ports in a single IOC? Mark Rivers via Tech-talk
Prev: caproto-monitor exits when IOC exits too Rute Mendes via Tech-talk
Next: Timestamp reset event in EVR Di Wang via Tech-talk
Prev: Re: How can I add multiple serial ports in a single IOC? Mark Rivers via Tech-talk
Next: caproto-monitor exits when IOC exits too Rute Mendes via Tech-talk
