Subject: Timestamp reset event in EVR
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Wed, 18 Mar 2020 01:13:07 +0900
Hi Michael,
  I found an event lost situation in my MRF VME-EVR-230RF, so I am wondering how will mrfioc2 handle the event received right after the timestamp reset event (i.e. 125) ?
We might send event code only 1 tick (i.e. 9 nanosecond) later than before one, so the 'right after' could be very fast. Here is a brief example.
Event       Timestamp
1           953053925.999,917,620
125       953053925.999,977,626  <-----TS reset event
2 <-----lost, and the timestamp should be 953053926.999,977,650
3            953053926.000,100,043
4            953053926.000,450,210
  I understand that when TS reset event is received the 32-bit seconds register will be reset, and below callback function would be called, but I still do not understand the process logic and the reason of event lost.
https://github.com/epics-modules/mrfioc2/blob/7bee26590cb5fea8117d0a12920bc281ab1c7cd8/evrMrmApp/src/drvem.cpp#L1430
  For you convenience, some information might help:
epics 3.15.5, devlib 2-2.10, mrfioc 2-2.2.0 (I added several functions to buffer the events in drvem.cpp) event clock: 114 MHz, repetition rate: 50 Hz, more than 120 events are monitored
Di WANG
Linac Control Group, KEK
Re: Timestamp reset event in EVR Michael Davidsaver via Tech-talk
Prev: Re: How can I add multiple serial ports in a single IOC? Lang, Keenan C. via Tech-talk
Next: RE: caproto-monitor exits when IOC exits too Allan, Daniel via Tech-talk
Prev: RE: caproto-monitor exits when IOC exits too Allan, Daniel via Tech-talk
Next: Re: Timestamp reset event in EVR Michael Davidsaver via Tech-talk
