Subject: Re: database "diff"
From: "DiMonte, Nicholas via Tech-talk" <[email protected]>
To: Paul Sichta <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Mar 2020 22:35:25 +0000
Paul,
At the APS we had GDCT modified to add convert function to VDCT. The conversion maintained the graphical layout which was really nice. We only have a Solaris build if my memory serves me right.
Andrew Johnson might be able to help you get a copy of this version.
Nicholas D.
On 3/20/20 1:44 PM, Paul Sichta via Tech-talk wrote:
We're converting our (~200) databases from gdct to vdct.  After we drag around the records in vdct to visually arrange the linked records, we want to perform a final check to compare the original and the vdct records. We plan to write a text processing program/script to do this,  but...
Has anyone made a tool to compare the records and their fields in two database files?  Is there a utility (in the IOC) to dump a database report that we can compare (before/after)?  Does the old dbreport extension provide reports that list a record's field information that we can compare?
We're doing this because gdct doesn't run on Linux (right?).
-ps
RE: database "diff" Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
database "diff" Paul Sichta via Tech-talk
Prev: Re: [EXTERNAL] database "diff" Pedro Gigoux via Tech-talk
Next: Re: Timestamp reset event in EVR Di Wang via Tech-talk
Next: RE: database "diff" Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
