Subject: RE: database "diff"
From: "Mercado, Ronaldo \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "'DiMonte, Nicholas'" <[email protected]>, Paul Sichta <[email protected]>
Date: Mon, 23 Mar 2020 09:52:03 +0000
Hi.
I don’t use VDCT or GDCT, only epics databases.
I built a linux tool (attached) to compare databases using the parser from epics base.
I hope it’s useful.
I found that it only works for old versions of epics (3.14.12.x) because the dbStaticHost library is no longer built in epics base.
(Why not?)
To build, edit the makefile to point to epics base also edit ‘scompare.conf’ to point to your paths,dbd files and db files.
The ‘path’ line accepts colon separated folders. I generally use it like that, listing the dbd and db folder for my iocs.
Ronaldo
From: Tech-talk <[email protected]> On Behalf Of DiMonte, Nicholas via Tech-talk
Sent: 20 March 2020 22:35
To: Paul Sichta <[email protected]>; [email protected]
Subject: Re: database "diff"
Paul,
At the APS we had GDCT modified to add convert function to VDCT. The conversion maintained the graphical layout which was really nice. We only have a Solaris build if my memory serves me right.
Andrew Johnson might be able to help you get a copy of this version.
Nicholas D.
On 3/20/20 1:44 PM, Paul Sichta via Tech-talk wrote:
We're converting our (~200) databases from gdct to vdct.  After we drag around the records in vdct to visually arrange the linked records, we want to perform a final check to compare the original and the vdct records. We plan to write a text processing program/script to do this,  but...
Has anyone made a tool to compare the records and their fields in two database files?  Is there a utility (in the IOC) to dump a database report that we can compare (before/after)?  Does the old dbreport extension provide reports that list a record's field information that we can compare?
We're doing this because gdct doesn't run on Linux (right?).
-ps
Attachment: scompare.zip
Description: scompare.zip
database "diff" Paul Sichta via Tech-talk
Re: database "diff" DiMonte, Nicholas via Tech-talk
Prev: Re: Timestamp reset event in EVR Di Wang via Tech-talk
Next: support for CryoStream 800? Jemian, Pete R. via Tech-talk
Prev: Re: database "diff" DiMonte, Nicholas via Tech-talk
