1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
From: "CORNALL, Terry via Tech-talk" <[email protected]>
Date: Wed, 1 Apr 2020 00:58:53 +0000
Hi All.
In streamDevice protocol, how can I send something to a record when @replyTimeout gets triggered, in order to detect complete comms failure?
I've used  exec and dbpf successfully e.g. something like
@replyTimeout {exec 'dbpf \$5 1'}
and that works, but I really don't like it that dbpf causes the IOCsh output to be cluttered up.
Is there some other way? None of the other commands available to streamDevice appear to be able to write to records, except the 'in' and that won't do anything if there are no comms sending stuff (I don't think).
Any way to get 'out' to write to a record instead of to the device? Or something I can 'exec' that affects a record but doesn't cause any IOCsh output?
Or is a different approach needed? Say something in the database that if a successful 'in' hasn't happened recently causes a 'comms error' to be set, rather than using streamDevice replyTimeout.
Thanks for your thoughts,
Terry
Prev: Re: EPICS7 roller-coaster Michael Davidsaver via Tech-talk
Next: RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
