1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
To: "CORNALL, Terry" <[email protected]>
Date: Wed, 1 Apr 2020 03:39:16 +0000
 Hi Terry,
Another solution would be to do the following:
- On the asyn port set the option "disconnectOnReadTimeout".  That way if the device does not respond it will disconnect the port.
- Load an asyn record that is connected to that asyn port.
- The asyn record CNCT field will change state when the port disconnects on read timeout.
- Use the CNCT field to control the COMSFAIL record.
IMHO this is a cleaner solution that does not involving launching a separate process.
From: Tech-talk <[email protected]> on behalf of CORNALL, Terry via Tech-talk <[email protected]>
Sent: Tuesday, March 31, 2020 9:20 PM
To: [email protected]
Subject: RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
For the record, I'll put a nice answer here that I got from James Larson.
'At the end of your exec statement
direct the output, >,  to /dev/null .  It won't show up on the ioc .'
I tried that and it works a treat.
In the protocol file:
commsFail {
  #exec 'echo "comms fail on \$0"'; #Turn this off in production
  exec 'dbpf \$1:\$4 "Comms error"> /dev/null';  #/dev/null makes it silent
readCurrent{
.... Usual out and in stuff, then an exception handler for timeout
              @replytimeout{commsFail;} #comms is down
And in the database file:
#COMMSFAIL is the record to write to on a replytimeout
  field(INP, "@$(DEVICE).proto readCurrents($(P)$(R),ITIME_MON,OVR_STS,COMMSFAIL) $(PORT) 0")
Thanks James.
Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Johnson, Andrew N. via Tech-talk
RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Prev: RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Next: Re: Newport DL325 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Johnson, Andrew N. via Tech-talk
