Subject: Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "CORNALL, Terry" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 1 Apr 2020 15:23:42 +0000
On Mar 31, 2020, at 10:39 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
IMHO this is a cleaner solution that does not involving launching a separate process.
In the protocol file:
commsFail {
 #exec 'echo "comms fail on \$0"'; #Turn this off in production
 exec 'dbpf \$1:\$4 "Comms error"> /dev/null';  #/dev/null makes it silent
Strictly speaking an “exec” command in a StreamDevice protocol file isn't actually launching a separate process, it’s just running “dbpf” as an iocShell command, which I assume happens in the context of whatever thread is executing the protocol. You could run an external process if your exec string starts with the iocsh command “system” to launch it, but that isn’t what the above protocol snippet is doing.
</pedantic>
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
Prev: RE: NTNDArray array filter does not work on value Mark Rivers via Tech-talk
Next: CS-STUDIO/BEAST Alarms to logstash? John Dobbins via Tech-talk
Prev: Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
