Subject: Problem with opening files in ADVimba
From: Jong Woo Kim via Tech-talk <[email protected]>
Date: Wed, 1 Apr 2020 17:21:56 +0000
Hello,
When I run ADVimba ioc, I've got the following things.
EPICS 3.15.6
ADVimba R1-2
ADGenICam R1-3
[root@b iocVimba]# ../../bin/linux-x86_64/vimbaApp st.cmd
< envPaths
epicsEnvSet("IOC","iocVimba")
epicsEnvSet("TOP","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC")
epicsEnvSet("ADVIMBA","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../..")
epicsEnvSet("SUPPORT","/usr/local/EPICS_NEW/synApps_6_1/support")
epicsEnvSet("ASYN","/usr/local/EPICS_NEW/synApps_6_1/support/asyn4-37")
epicsEnvSet("AREA_DETECTOR","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector")
epicsEnvSet("ADSUPPORT","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADSupport")
epicsEnvSet("ADCORE","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore")
epicsEnvSet("AUTOSAVE","/usr/local/EPICS_NEW/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("BUSY","/usr/local/EPICS_NEW/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("CALC","/usr/local/EPICS_NEW/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("SNCSEQ","/usr/local/EPICS_NEW/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("SSCAN","/usr/local/EPICS_NEW/synApps_6_1/support/sscan-R2-11-3")
epicsEnvSet("DEVIOCSTATS","/usr/local/EPICS_NEW/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/usr/local/EPICS_NEW/base-3.15.6")
epicsEnvSet("ADGENICAM","/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam")
errlogInit(20000)
dbLoadDatabase("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/dbd/vimbaApp.dbd")
vimbaApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "13VMB1:")
epicsEnvSet("CAMERA_ID", "10.139.1.11")
epicsEnvSet("MODULE","ADVimba:")
epicsEnvSet("GENICAM_DB_FILE", "/usr/local/CXLS_SW/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db/AVT_Mako_G507B.template")
# The port name for the detector
epicsEnvSet("PORT",   "VMB1")
# Really large queue so we can stream to disk at full camera speed
epicsEnvSet("QSIZE",  "2000")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2464")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "2056")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/db;/usr/local/CXLS_SW/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../db")
# Define NELEMENTS to be enough for a 2048x2048x3 (color) image
epicsEnvSet("NELEMENTS","15197952")
# ADVimbaConfig(const char *portName, const char *cameraId,
#                   size_t maxMemory, int priority, int stackSize)
ADVimbaConfig("VMB1", 10.139.1.11,0,0,0)
asynSetTraceIOMask(VMB1, 0, 2)
# Set ASYN_TRACE_WARNING and ASYN_TRACE_ERROR
#asynSetTraceMask($(PORT), 0, 0xff)
#asynSetTraceFile($(PORT), 0, "asynTrace.out")
#asynSetTraceInfoMask($(PORT), 0, 0xf)
dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../db/vimba.template", "P=13VMB1:,R=ADVimba:,PORT=VMB1")
Can't open include file "ADGenICam.template"
Error at or before ""ADGenICam.template"" in file "/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADVimba/iocs/vimbaIOC/../../db/vimba.template" line 9
# Load the autogenerated file of GenICam features
dbLoadRecords("/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db/AVT_Mako_G507B.template", "P=13VMB1:,R=GenICam,PORT=VMB1")
Can't set "13VMB1:GenICamGC_FirmwareVerMajor_RBV.DTYP" to "asynInt64"
Error at or before ")" in file "/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADGenICam/db/AVT_Mako_G507B.template" line 9
Can't set "13VMB1:GenICamGC_FirmwareVerMajor.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_FirmwareVerMinor_RBV.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_FirmwareVerMinor.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_FirmwareVerBuild_RBV.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_FirmwareVerBuild.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_SensorBits_RBV.DTYP" to "asynInt64"
ErrorCan't set "13VMB1:GenICamGC_SensorBits.DTYP" to "asynInt64"
auto_settings.sav: 30 of 2245 PV's connected
Jong Woo
RE: Problem with opening files in ADVimba Engbretson, Mark S. via Tech-talk
Re: Problem with opening files in ADVimba Mark Rivers via Tech-talk
Prev: CS-STUDIO/BEAST Alarms to logstash? John Dobbins via Tech-talk
Next: RE: Problem with opening files in ADVimba Engbretson, Mark S. via Tech-talk
Prev: Re: CS-STUDIO/BEAST Alarms to logstash? Shroff, Kunal via Tech-talk
