1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Packages to build EPICS base, synApps, and areaDetector on Centos 8
From: "Pedersen, Ulrik \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 3 Apr 2020 10:12:55 +0000
Thank you Mark!!! This is incredibly helpful!
Did you or anyone else here on Tech-talk happen to have a go at building EDM on CentOS8?
Cheers,
Ulrik
Ulrik Kofoed Pedersen
Head of Beamline Controls
Diamond Light Source Ltd
Phone: +44 1235 77 8580
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 02 April 2020 20:06
To: [email protected] <[email protected]>
Subject: Packages to build EPICS base, synApps, and areaDetector on Centos 8
Folks,
I recently set up a new Centos 8 system with EPICS, synApps, and areaDetector (including ADAravis, ADEiger, and ADVimba).  To do so I needed to install nearly 30 Linux packages.  I have attached a Word document listing all of the packages I needed to install, and also all of the other packages that were installed as dependencies.
I thought this might save others some time in determining just what packages are needed when they run into errors building on new Linux installations.
RE: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Mark Rivers via Tech-talk
Prev: Re: NTNDArray array filter does not work on value Marty Kraimer via Tech-talk
Next: Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Mark Rivers via Tech-talk
Next: RE: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Mark Rivers via Tech-talk
