1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Packages to build EPICS base, synApps, and areaDetector on Centos 8
Date: Thu, 2 Apr 2020 19:06:46 +0000
Folks,
I recently set up a new Centos 8 system with EPICS, synApps, and areaDetector (including ADAravis, ADEiger, and ADVimba).  To do so I needed to install nearly 30 Linux packages.  I have attached a Word document listing all of the packages I needed to install, and also all of the other packages that were installed as dependencies.
I thought this might save others some time in determining just what packages are needed when they run into errors building on new Linux installations.
Attachment: EPICS_Centos8_Packages.docx
Description: EPICS_Centos8_Packages.docx
Re: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Pedersen, Ulrik (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Macro substitution for a filename Daykin, Evan via Tech-talk
Next: Re: NTNDArray array filter does not work on value Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Pedersen, Ulrik (DLSLtd, RAL, LSCI) via Tech-talk
