Subject: Re: EDM in RHEL8 or Centos8
From: "Williams Jr., Ernest L. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Ernesto Paiser <[email protected]>
Date: Fri, 3 Apr 2020 14:49:08 +0000
Hi Ernesto,
How is it going?
Our production systems are using mainly RHEL6 and RHEL7.
I have started looking ahead to RHEL 8.
What version of EDM are you using there?
Please provide more detail:
  1. Version of EPICS
  2. Version of EDM
  3. Version of giflib
Here is what I have on my centos8 box:
OS = CentOS Linux release 8.1.1911 (Core)
EPICS BASE = 7.0.3.1
EDM = 1.12.105B
GIFLIB = giflib-devel-5.1.4-3.el8.x86_64
Looks like we have a problem.
Here is my error message:
make -C ./giflib install
make[1]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -std=c++98 -fpermissive -Wno-write-strings -DNO_UNORDERED_MAP -DSINGLE_THREADED=1 -D__epics__=1  -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include          -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/compiler/gcc -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/os/Linux -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include     -I../../util -I../../edmlib -I/usr/include -I/usr/include/X11    -c ../gif.cc
../gif.cc: In constructor ‘activeGifClass::activeGifClass(const activeGifClass*)’:
../gif.cc:245:5: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
 int status;
../gif.cc: In member function ‘int activeGifClass::readGifFile()’:
../gif.cc:24:50: error: too few arguments to function ‘GifFileType* DGifOpenFileName(const char*, int*)’
   #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif)
../gif.cc:442:11: note: in expansion of macro ‘GIF_OPEN_FILE’
     gif = GIF_OPEN_FILE( name );
In file included from ../gif.h:28,
                 from ../gif.cc:39:
/usr/include/gif_lib.h:179:14: note: declared here
 GifFileType *DGifOpenFileName(const char *GifFileName, int *Error);
../gif.cc:23:48: error: too few arguments to function ‘int DGifCloseFile(GifFileType*, int*)’
   #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif)
../gif.cc:898:12: note: in expansion of macro ‘GIF_CLOSE_FILE’
   status = GIF_CLOSE_FILE( gif );
                 from ../gif.cc:39:
/usr/include/gif_lib.h:183:9: note: declared here
     int DGifCloseFile(GifFileType * GifFile, int *ErrorCode);
../gif.cc:910:30: note: in expansion of macro ‘GIF_CLOSE_FILE’
   if ( fileOpened ) status = GIF_CLOSE_FILE( gif );
                 from ../gif.cc:39:
make[2]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_BUILD:251: gif.o] Error 1
make[2]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64'
make[1]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib'
make: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_DIRS:84: giflib.install] Error 2'
Cheers,
Ernesto
Re: EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Prev: Re: Setting an array to zero length Ralph Lange via Tech-talk
Next: RE: Packages to build EPICS base, synApps, and areaDetector on Centos 8 Mark Rivers via Tech-talk
Prev: EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Next: Re: EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
