Subject: Re: EDM in RHEL8 or Centos8
From: Ernesto Paiser via Tech-talk <[email protected]>
To: "Williams Jr., Ernest L." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Apr 2020 09:10:14 -0700
Hi Ernest,
I reached that point too.
There was a threat in teck-talk that talk about don't need libungif anymore. I tried to replace it with giflib, but it didn't work.
I got some emails from Sinclair I will still need to check it.
Let you know my progress.
 Cheers
  Ernesto
On 4/3/20 8:59 AM, Williams Jr., Ernest L. wrote:
Response below
*Sent:* Friday, April 3, 2020 8:46 AM
*To:* Williams Jr., Ernest L. <[email protected]>; [email protected] <[email protected]>
*Subject:* Re: EDM in RHEL8 or Centos8
Hi Ernest,
I'm doing well. Regardless someone here may have got the covid...
Hope you are as well as, safe and healthy!
<ELW>
We are hanging in there.
Shelter In Place 🙂
<ELW>
This message you got is because the gif.cc should check the giflib
version and set the #define accordingly, but isn't working.
giflib has changed the definition for the functions:
DGifCloseFile and DGifOpenFileName
since version 5 adding an additional parameter *errno for the arguments.
If you force to compile with giflib version 5.1 you'll  get rid of this
error, but you may found others like me.
To make a test just modify gif.cc as:
//#if GIFLIB_MAJOR > 5 || GIFLIB_MAJOR == 5 && GIFLIB_MINOR >= 1
    #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif, NULL)
    #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif, NULL)
//#else
//  #define GIF_CLOSE_FILE(gif) DGifCloseFile(gif)
//  #define GIF_OPEN_FILE(gif) DGifOpenFileName(gif)
//#endif
and compile again.
<ELW>
That stanza needs to be moved below the "#include "gif.h""
gif.h  which includes gif_lib.h which defines GIFLIB_MAJOR and GIFLIB_MINOR
I guess this went unnoticed for a long time 🙁
Version logic is working now.
<ELW>
Let me know if you make some progress, Thanks
<ELW>
Next, issue is linking error; seems that libungif is needed
make[1]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64' /usr/bin/g++ -o libcf322683-513e-4570-a44b-7cdd7cae0de5.so -shared -fPIC -Wl,-hlibcf322683-513e-4570-a44b-7cdd7cae0de5.so -L/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/lib/linux-x86_64 -L/usr/lib64 -Wl,-rpath,/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/lib/linux-x86_64 -Wl,-rpath,/usr/lib64           -rdynamic -m64          gif.o reg_libcf322683-513e-4570-a44b-7cdd7cae0de5.o   -lEdmBase -lcfcaa62e-8199-11d3-a77f-00104b8742df -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXt -lXp -lXtst -lX11  -lpthread -ldl -lungif -lgif -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lungif
collect2: error: ld returned 1 exit status
<ELW>
   Ernesto
On 4/3/20 7:49 AM, Williams Jr., Ernest L. wrote:
Hi Ernesto,
How is it going?
Our production systems are using mainly RHEL6 and RHEL7.
I have started looking ahead to RHEL 8.
What version of EDM are you using there?
Please provide more detail:
  1. Version of EPICS
  2. Version of EDM
  3. Version of giflib
Here is what I have on my centos8 box:
OS = CentOS Linux release 8.1.1911 (Core)
EPICS BASE = 7.0.3.1
EDM = 1.12.105B
GIFLIB = giflib-devel-5.1.4-3.el8.x86_64
Looks like we have a problem.
Here is my error message:
make -C ./giflib install
make[1]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
      T_A=linux-x86_64 install
make[2]: Entering directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64' /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_    -DUNIX  -Dlinux     -O3   -Wall     -std=c++98 -fpermissive -Wno-write-strings -DNO_UNORDERED_MAP -DSINGLE_THREADED=1 -D__epics__=1    -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/compiler/gcc -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include/os/Linux -I/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/include -I../../util -I../../edmlib -I/usr/include -I/usr/include/X11    -c ../gif.cc ../gif.cc: In constructor ‘activeGifClass::activeGifClass(const activeGifClass*)’: ../gif.cc:245:5: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
   int status;
../gif.cc: In member function ‘int activeGifClass::readGifFile()’:
../gif.cc:24:50: error: too few arguments to function ‘GifFileType* DGifOpenFileName(const char*, int*)’
../gif.cc:442:11: note: in expansion of macro ‘GIF_OPEN_FILE’
       gif = GIF_OPEN_FILE( name );
In file included from ../gif.h:28,
                   from ../gif.cc:39:
/usr/include/gif_lib.h:179:14: note: declared here
   GifFileType *DGifOpenFileName(const char *GifFileName, int *Error);
../gif.cc:23:48: error: too few arguments to function ‘int DGifCloseFile(GifFileType*, int*)’
../gif.cc:898:12: note: in expansion of macro ‘GIF_CLOSE_FILE’
     status = GIF_CLOSE_FILE( gif );
                   from ../gif.cc:39:
/usr/include/gif_lib.h:183:9: note: declared here
       int DGifCloseFile(GifFileType * GifFile, int *ErrorCode);
../gif.cc:910:30: note: in expansion of macro ‘GIF_CLOSE_FILE’
     if ( fileOpened ) status = GIF_CLOSE_FILE( gif );
                   from ../gif.cc:39:
make[2]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_BUILD:251: gif.o] Error 1 make[2]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib/O.linux-x86_64' make[1]: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_ARCHS:58: install.linux-x86_64]
Error 2
make[1]: Leaving directory '/usr/local/controlsDev/epics/extensions/edm/R1.12.105B-1.2.0/giflib' make: *** [/usr/local/controlsDev/epics/base/R7.0.3.1-1.0/configure/RULES_DIRS:84: giflib.install] Error 2'
Cheers,
Ernesto
Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Re: EDM in RHEL8 or Centos8 Ernesto Paiser via Tech-talk
Prev: Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
Next: Re: EDM in RHEL8 or Centos8 Williams Jr., Ernest L. via Tech-talk
