1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: 'System.dbd' in EPICS base
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Mogamad Amien Crombie <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 6 Apr 2020 15:28:14 +0000
Hi Amien,
On Apr 4, 2020, at 2:20 AM, Mogamad Amien Crombie via Tech-talk <[email protected]> wrote:
Sometimes we have to do some 'system' calls from inside EPICS shell.
As far as I know, the normal way is to add the 'system.dbd' to the IOC's /src/app Makefile.
Is it possible to have this in oun Epics Base so that it is enabled for all our IOC's ?  The 'ReadLine' (shell history etc) is done inside the base .
You can of course make any changes you like to the code in your Base installation before you build it. We don’t have a build configuration flag that adds system.dbd to all IOCs, so the easiest way for you to achieve this would be to edit the file Base-3.15.x/src/std/softIoc/base.dbd or Base-7.0/modules/database/src/std/softIoc/base.dbd and add a line
include “system.dbd”
to the end of that file. Personally I would handle that requirement slightly differently though – our operational IOCs all build with a locally developed support module that provides common standard facilities, and I would put that kind of setting into our iocStdSoft.dbd file instead of modifying base.dbd
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
'System.dbd' in EPICS base Mogamad Amien Crombie via Tech-talk
Prev: Re: Contributing a new how-to to the EPICS web site Konrad, Martin via Tech-talk
Next: Re: Contributing a new how-to to the EPICS web site Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: 'System.dbd' in EPICS base Mogamad Amien Crombie via Tech-talk
Next: test automation tools on Control System studio screens Hinko Kocevar via Tech-talk
