1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: ci-scripts 2.2.0 available
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 6 Apr 2020 19:17:01 +0200
ci-scripts 2.2.0 features:
  • rebuild all remaining dependencies once a dependency is found out-of-date
  • add convenience setup files for dependency versions used in recent synApps releases
  • automatically add MSI 1.7 when checking-out Base 3.14 releases
  • make CACHEDIR configurable to support local debugging
  • add per-job setting to define additional dependency modules.
This is a minor release, i.e. existing configuration does not need to be changed except for using new features.
Use the tracker to see the issues closed with this release.
Instructions how to update your software module can be found in the README's FAQ section.
Cheers,
~Ralph
Prev: Corrupted bob files CSS William Smith - UKRI STFC via Tech-talk
Next: Re: Corrupted bob files CSS Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Corrupted bob files CSS Kasemir, Kay via Tech-talk
Next: plugins/EPICS_areaDetector in ImageJ Jong Woo Kim via Tech-talk
