1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: plugins/EPICS_areaDetector in ImageJ
From: Jong Woo Kim via Tech-talk <[email protected]>
Date: Mon, 6 Apr 2020 21:40:04 +0000
Hi All,
I copied ADViewers/Image/EPICS_areaDetector and pasted it to /ImageJ/plugins.
After opening ImageJ, I went into plugins/compile and run, then chose EPICS_AD_Controller.java.
The following message came out. Do you know what is missing?
_________________________________________________________________________
ImageJ 1.52a; Java 1.8.0_112 [64-bit]; Linux 3.10.0-862.6.3.el7.x86_64; 32MB of 455MB (7%)
warning: [options] bootstrap class path not set in conjunction with -source 1.6
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:21: error: package gov.aps.jca does not exist
import gov.aps.jca.*;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:22: error: package gov.aps.jca.dbr does not exist
import gov.aps.jca.dbr.*;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:23: error: package gov.aps.jca.configuration does not exist
import gov.aps.jca.configuration.*;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:24: error: package gov.aps.jca.event does not exist
import gov.aps.jca.event.*;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:44: error: cannot find symbol
    JCALibrary jca;
  symbol:   class JCALibrary
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:45: error: cannot find symbol
    DefaultConfiguration conf;
  symbol:   class DefaultConfiguration
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:46: error: cannot find symbol
    Context ctxt;
  symbol:   class Context
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:49: error: cannot find symbol
    Channel ch_maxSizeCamX;       //This is the maximum dimension of X
  symbol:   class Channel
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:50: error: cannot find symbol
    Channel ch_maxSizeCamY;       //This is the maximum dimension of Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:51: error: cannot find symbol
    Channel ch_minCamX;           //This is the start of the CCD readout in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:52: error: cannot find symbol
    Channel ch_minCamY;           //This is the start of the CCD readout in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:53: error: cannot find symbol
    Channel ch_minCamX_RBV;       //This is the readback value of X of the CCD readout
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:54: error: cannot find symbol
    Channel ch_minCamY_RBV;       //This is the readback value of Y of the CCD readout
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:55: error: cannot find symbol
    Channel ch_sizeCamX;          //This is the size of the CCD readout in the X dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:56: error: cannot find symbol
    Channel ch_sizeCamY;          //This is the size of the CCD readout in the Y dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:57: error: cannot find symbol
    Channel ch_sizeCamArrayX_RBV; //This is the size of the image array of the CCD in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:58: error: cannot find symbol
    Channel ch_sizeCamArrayY_RBV; //This is the size of the image array of the CCD in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:59: error: cannot find symbol
    Channel ch_binCamX_RBV;       //This is the amount of binning for the CCD readout in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:60: error: cannot find symbol
    Channel ch_binCamY_RBV;       //This is the amount of binning for the CCD readout in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:61: error: cannot find symbol
    Channel ch_reverseCamX_RBV;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:62: error: cannot find symbol
    Channel ch_reverseCamY_RBV;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:64: error: cannot find symbol
    Channel ch_minRoiX;           //This is the start of the ROI in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:65: error: cannot find symbol
    Channel ch_minRoiY;           //This is the start of the ROI in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:66: error: cannot find symbol
    Channel ch_minRoiX_RBV;       //This is the readback value of X in the ROI
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:67: error: cannot find symbol
    Channel ch_minRoiY_RBV;       //This is the readback value of Y in the ROI
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:68: error: cannot find symbol
    Channel ch_binRoiX;           //This is the binning of the ROI in the X dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:69: error: cannot find symbol
    Channel ch_binRoiY;           //This is the binning of the ROI in the Y dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:70: error: cannot find symbol
    Channel ch_sizeRoiX;          //This is the size of the ROI in the X dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:71: error: cannot find symbol
    Channel ch_sizeRoiY;          //This is the size of the ROI in the Y dimension
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:72: error: cannot find symbol
    Channel ch_sizeRoiArrayX_RBV; //This is the size of the image array for the ROI in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:73: error: cannot find symbol
    Channel ch_sizeRoiArrayY_RBV; //This is the size of the image array for the ROI in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:74: error: cannot find symbol
    Channel ch_reverseRoiX_RBV;       //This is reverse flag for the ROI in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:75: error: cannot find symbol
    Channel ch_reverseRoiY_RBV;       //This is reverse flag for the ROI in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:77: error: cannot find symbol
    Channel ch_transType;         //This represents the way the image is flipped or rotated.
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:78: error: cannot find symbol
    Channel ch_transArrayX_RBV;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:79: error: cannot find symbol
    Channel ch_transArrayY_RBV;
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:81: error: cannot find symbol
    Channel ch_minOverlayX;       //This is the position of the overlay in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:82: error: cannot find symbol
    Channel ch_minOverlayY;       //This is the position of the overlay in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:83: error: cannot find symbol
    Channel ch_sizeOverlayX;      //This is the size of the overlay in X
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:84: error: cannot find symbol
    Channel ch_sizeOverlayY;      //This is the size of the overlay in Y
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:650: error: cannot find symbol
    public Channel createEPICSChannel(String chname) throws Exception {
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:823: error: cannot find symbol
    public int epicsGetInt(Channel ch) throws TimeoutException, CAException, IllegalStateException {
  symbol:   class TimeoutException
  symbol:   class CAException
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:841: error: cannot find symbol
    public short epicsGetEnum(Channel ch) throws TimeoutException, CAException, IllegalStateException {
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:859: error: cannot find symbol
    public void epicsSetInt(Channel ch, int num) throws TimeoutException, CAException, IllegalStateException {
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:218: error: cannot find symbol
            } catch (CAException ex) {
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:220: error: cannot find symbol
            } catch (TimeoutException ex) {
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:239: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:241: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:258: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:260: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:280: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:282: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:304: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:306: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:540: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:559: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:587: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:607: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:624: error: cannot find symbol
            jca = JCALibrary.getInstance();
  symbol:   variable JCALibrary
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:625: error: cannot find symbol
            ctxt = jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:627: error: cannot find symbol
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:652: error: cannot find symbol
        Channel ch = ctxt.createChannel(chname);
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:679: error: package Channel does not exist
              (ch_minCamX != null && ch_minCamX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:680: error: package Channel does not exist
            && ch_minCamY != null && ch_minCamY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:681: error: package Channel does not exist
            && ch_minCamX_RBV != null && ch_minCamX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:682: error: package Channel does not exist
            && ch_minCamY_RBV != null && ch_minCamY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:683: error: package Channel does not exist
            && ch_sizeCamX != null && ch_sizeCamX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:684: error: package Channel does not exist
            && ch_sizeCamY != null && ch_sizeCamY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:685: error: package Channel does not exist
            && ch_maxSizeCamX != null && ch_maxSizeCamX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:686: error: package Channel does not exist
            && ch_maxSizeCamY != null && ch_maxSizeCamY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:687: error: package Channel does not exist
            && ch_binCamX_RBV != null && ch_binCamX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:688: error: package Channel does not exist
            && ch_binCamY_RBV != null && ch_binCamY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:689: error: package Channel does not exist
            && ch_reverseCamX_RBV != null && ch_reverseCamX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:690: error: package Channel does not exist
            && ch_reverseCamY_RBV != null && ch_reverseCamY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:691: error: package Channel does not exist
            && ch_sizeCamArrayX_RBV != null && ch_sizeCamArrayX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:692: error: package Channel does not exist
            && ch_sizeCamArrayY_RBV != null && ch_sizeCamArrayY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED);
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:714: error: package Channel does not exist
            transformConnected = (ch_transType != null && ch_transType.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:715: error: package Channel does not exist
                               && ch_transArrayX_RBV != null && ch_transArrayX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:716: error: package Channel does not exist
                               && ch_transArrayY_RBV != null && ch_transArrayY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED);
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:747: error: package Channel does not exist
                  (ch_minRoiX != null && ch_minRoiX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:748: error: package Channel does not exist
                && ch_minRoiY != null && ch_minRoiY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:749: error: package Channel does not exist
                && ch_minRoiX_RBV != null && ch_minRoiX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:750: error: package Channel does not exist
                && ch_minRoiY_RBV != null && ch_minRoiY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:751: error: package Channel does not exist
                && ch_binRoiX != null && ch_binRoiX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:752: error: package Channel does not exist
                && ch_binRoiY != null && ch_binRoiY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:753: error: package Channel does not exist
                && ch_reverseRoiX_RBV != null && ch_reverseRoiX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:754: error: package Channel does not exist
                && ch_reverseRoiY_RBV != null && ch_reverseRoiY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:755: error: package Channel does not exist
                && ch_sizeRoiX != null && ch_sizeRoiX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:756: error: package Channel does not exist
                && ch_sizeRoiY != null && ch_sizeRoiY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:757: error: package Channel does not exist
                && ch_sizeRoiArrayX_RBV != null && ch_sizeRoiArrayX_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:758: error: package Channel does not exist
                && ch_sizeRoiArrayY_RBV != null && ch_sizeRoiArrayY_RBV.getConnectionState() == Channel.ConnectionState.CONNECTED);
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:780: error: package Channel does not exist
                      (ch_minOverlayX != null && ch_minOverlayX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:781: error: package Channel does not exist
                    && ch_minOverlayY != null && ch_minOverlayY.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:782: error: package Channel does not exist
                    && ch_sizeOverlayX != null && ch_sizeOverlayX.getConnectionState() == Channel.ConnectionState.CONNECTED
/usr/local/bin/ImageJ/plugins/EPICS_areaDetector/EPICS_AD_Controller.java:1034: warning: [unchecked] unchecked call to JComboBox(E[]) as a member of the raw type JComboBox
        outputSelectComboBox = new JComboBox(outputSelectChoices);
  where E is a type-variable:
    E extends Object declared in class JComboBox
100 errors
2 warnings
Re: plugins/EPICS_areaDetector in ImageJ Mark Rivers via Tech-talk
Prev: Re: Corrupted bob files CSS Kasemir, Kay via Tech-talk
Next: StreamDevice, prevent records from getting "stuck" Sobhani, Bayan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: ci-scripts 2.2.0 available Ralph Lange via Tech-talk
Next: Re: plugins/EPICS_areaDetector in ImageJ Mark Rivers via Tech-talk
