1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Galil device support - static build
From: John Dobbins via Tech-talk <[email protected]>
Date: Mon, 13 Apr 2020 14:31:31 +0000
All,
Doing a static build of Galil 3-6 device support I ran into the problem described below. Solved by changing order of libraries.
John Dobbins
For static build of Galil 3-6
In galil/3-6/GalilTestApp/src
I changed Makefile from
GalilTest_LIBS += asyn motor calc sscan autosave busy
GalilTest_LIBS += GalilSupport
GalilTest_LIBS += $(EPICS_BASE_IOC_LIBS)
to
because of link error:
/usr/bin/g++ -o GalilTest -Wl,-Bstatic -L/nfs/chess/user/jad22/epics/support/galil/3-6/lib/linux-x86_64 -L/nfs/chess/epics/release/base/base-7.0.2/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/asyn-R4-38/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/motor-R7-1/lib/linux-x86_64 -L/nfs/chess/epics/release/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64            -rdynamic -m64 GalilTest_registerRecordDeviceDriver.o GalilTestMain.o -lasyn -lmotor -lcalc -lsscan -lautosave -lbusy -lGalilSupport -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lpthread -lreadline -lm -lrt -ldl -lgcc
/nfs/chess/user/jad22/epics/support/galil/3-6/lib/linux-x86_64/libGalilSupport.a(GalilController.o): In function `GalilCreateAxis':
/nfs/chess/user/jad22/epics/support/galil/3-6/GalilSup/src/O.linux-x86_64/../GalilController.cpp:7242: undefined reference to `findAsynPortDriver(char const*)'
[When you specify multiple inter-dependent static libraries via -l flag  dependents must go first, then their dependencies.]
Re: Galil device support - static build Mooney, Tim M. via Tech-talk
Prev: Re: enable PV searching only over TCP Michael Davidsaver via Tech-talk
Next: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Galil device support - static build Mooney, Tim M. via Tech-talk
