Subject: Re: [EXTERNAL] AlarmServer: No Connection and UNDEFINED
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, LiuP <[email protected]>
Date: Fri, 17 Apr 2020 15:30:21 +0000
> .. X05U1:FM:TC is on .. other network: 10.30.78.YY, the port is 5066
Yes, when you have several networks, you need to configure the address list, for example by listing the broadcast addresses of all relevant subnets.
You best put the same address list settings in the  plugin_customization.ini that you use with the CSS GUI and the alarm server, that way you can test the settings in the GUI.
> I think the right way is  to modify the plugin_customization.ini file:
>       org.csstudio.platform.libs.epics/addr_list="10.30.78.246:5066"
The "org.csstudio.platform.libs.epics/addr_list" was the original name for that preference in the Eclipse-based CSS.
But then DIIRT simplified matters by adding its own setting, and feeling left out, VType.PV did the same.
So best set all 3:
org.csstudio.platform.libs.epics/addr_list=...
org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list=...
org.csstudio.vtype.pv/addr_list=..
Sorry,
Kay
AlarmServer: No Connection and UNDEFINED LiuP via Tech-talk
Prev: AlarmServer: No Connection and UNDEFINED LiuP via Tech-talk
Next: Re: AlarmServer: No Connection and UNDEFINED LiuP via Tech-talk
