Subject: Re: AlarmServer: No Connection and UNDEFINED
To: "'Kasemir, Kay'" <[email protected]>, <[email protected]>
Date: Mon, 20 Apr 2020 13:35:12 +0800
Thank you, Kay.
My problem was been solved according to your guide.
Set:
org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list=10.30.78.246:506
6 10.30.78.246:5070
But the addr-list must not be enclosed in double quotes , suan as
"10.30.78.246:5066 10.30.78.246:5070".
LIU Ping
 Kasemir, Kay [mailto:[email protected]]
 2020.4.17 23:30
 [email protected]; LiuP <[email protected]>
 Re: [EXTERNAL] AlarmServer: No Connection and UNDEFINED
> .. X05U1:FM:TC is on .. other network: 10.30.78.YY, the port is 5066
Yes, when you have several networks, you need to configure the address list,
for example by listing the broadcast addresses of all relevant subnets.
You best put the same address list settings in
the  plugin_customization.ini that you use with the CSS GUI and the alarm
server, that way you can test the settings in the GUI.
> I think the right way is  to modify the plugin_customization.ini file:
>       org.csstudio.platform.libs.epics/addr_list="10.30.78.246:5066"
The "org.csstudio.platform.libs.epics/addr_list" was the original name for
that preference in the Eclipse-based CSS.
But then DIIRT simplified matters by adding its own setting, and feeling
left out, VType.PV did the same.
So best set all 3:
org.csstudio.platform.libs.epics/addr_list=...
org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list=...
org.csstudio.vtype.pv/addr_list=..
Sorry,
Kay
Re: AlarmServer: No Connection and UNDEFINED Shen, Guobao via Tech-talk
Prev: Re: [EXTERNAL] AlarmServer: No Connection and UNDEFINED Kasemir, Kay via Tech-talk
Next: Re: AlarmServer: No Connection and UNDEFINED Shen, Guobao via Tech-talk
