1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: AlarmServer: No Connection and UNDEFINED
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: LiuP <[email protected]>, "'Kasemir, Kay'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 20 Apr 2020 15:26:47 +0000
It seems that there are 2 functions, which are neither issues nor bugs, to be improved to be more user friendly.
1. Double quotes in setting:
org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list="10.30.78.246:5066 10.30.78.246:5070"
This is very often for CLI use case, but not acceptable in the ini file
2. Multiple setting for the same environment
    org.csstudio.platform.libs.epics/addr_list=...
    org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list=...
    org.csstudio.vtype.pv/addr_list=..
It would be nice to normalize it into one.
I did notice that the DIIRT setting has "diirt.ca.addr.list". Does that have to be CA, or it can apply to pva as well?
Guobao
On 4/20/20, 12:39 AM, "Tech-talk on behalf of LiuP via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Thank you, Kay.
    My problem was been solved according to your guide.
    Set:
    org.csstudio.diirt.util.core.preferences/diirt.ca.addr.list=10.30.78.246:506
    6 10.30.78.246:5070
    But the addr-list must not be enclosed in double quotes , suan as
    "10.30.78.246:5066 10.30.78.246:5070".
    LIU Ping
     Kasemir, Kay [mailto:[email protected]]
     2020.4.17 23:30
     [email protected]; LiuP <[email protected]>
     Re: [EXTERNAL] AlarmServer: No Connection and UNDEFINED
    > .. X05U1:FM:TC is on .. other network: 10.30.78.YY, the port is 5066
    Yes, when you have several networks, you need to configure the address list,
    for example by listing the broadcast addresses of all relevant subnets.
    You best put the same address list settings in
    the  plugin_customization.ini that you use with the CSS GUI and the alarm
    server, that way you can test the settings in the GUI.
    > I think the right way is  to modify the plugin_customization.ini file:
    >       org.csstudio.platform.libs.epics/addr_list="10.30.78.246:5066"
    The "org.csstudio.platform.libs.epics/addr_list" was the original name for
    that preference in the Eclipse-based CSS.
    But then DIIRT simplified matters by adding its own setting, and feeling
    left out, VType.PV did the same.
    So best set all 3:
    Sorry,
    Kay
Re: AlarmServer: No Connection and UNDEFINED LiuP via Tech-talk
Prev: Re: AlarmServer: No Connection and UNDEFINED LiuP via Tech-talk
Next: ADAravis JAI camera stops Steve Kinder - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
