Subject: Re: Tips for doing conditional logic in EPICS records
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 27 Apr 2020 18:16:44 +0200
On Mon, 27 Apr 2020 at 18:04, Mooney, Tim M. via Tech-talk <[email protected]> wrote:
One way to do conditional execution in an EPICS database is by using the SELM and SELN fields of a seq record.  Set SELM to "Specified", and write a number to the SELN field. If you want more than one of several things to happen, you can write "Mask" to SELM, and write a bitmap value to SELN, specifying which things to do.
+1
The combination of a calcout record (evaluating conditions) writing to a seq record in "Mask" mode (executing actions) is extremely powerful. As actions can include delays and changing the calcout's fields, that setup is good enough for a small state machine. (You will also win any district level obfuscation contest.)
Cheers,
~Ralph
Re: Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
Re: Tips for doing conditional logic in EPICS records Mooney, Tim M. via Tech-talk
Prev: Re: Tips for doing conditional logic in EPICS records Mooney, Tim M. via Tech-talk
Next: Re: Adding new record to EPICS 7 IOC with pvDatabase Joao Paulo Martins via Tech-talk
Next: Re: Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
