Subject: Re: Tips for doing conditional logic in EPICS records
To: [email protected]
Date: Thu, 30 Apr 2020 09:54:37 -0400
On 4/27/2020 12:16 PM, Ralph Lange via Tech-talk wrote:
On Mon, 27 Apr 2020 at 18:04, Mooney, Tim M. via Tech-talk <[email protected]> wrote:
One way to do conditional execution in an EPICS database is by using the SELM and SELN fields of a seq record.  Set SELM to "Specified", and write a number to the SELN field. If you want more than one of several things to happen, you can write "Mask" to SELM, and write a bitmap value to SELN, specifying which things to do.
+1
The combination of a calcout record (evaluating conditions) writing to a seq record in "Mask" mode (executing actions) is extremely powerful. As actions can include delays and changing the calcout's fields, that setup is good enough for a small state machine. (You will also win any district level obfuscation contest.)
Cheers,
~Ralph
The above comments by Tim and Ralph were the inspiration for the solution I decided on:
NOTE:  Some of the PP/NPP/CP/MS/NMS/etc values may need tweaking yet...)
record(ai, "I_RSET")  {
  field(DESC, "current set readback")
  field(PREC, "3")
  field(ADEL, "0.01")
record(bi, "_updateRSET")  {
  field(VAL,  "1")
  field(PINI, "YES")
record(scalcout, "_psInReset")  {
  field(DESC, "Is PS in reset state?")
  field(INAA, "CMD_STAT CP MSS")
  field(CALC, "AA = 'R'")
# Compute value for seq record bit-mask to specify which actions to perform
record(transform, "_RSET_UpdateLogic")
  field(INPA, "_psInReset CP MSS")
  field(INPB, "_updateRSET CP MSS")
  field(INPC, "ON_RSTS CP MSS")
  # if (psInReset == 1)  { I_RSET = 0;  updateRSET = 0; }  (actions 1 and 2: Mask=0x03)
  field(CLCJ, "(A=1) ? 3 : 0")
  # else  if (_ON_RSTS_ == 1)  { I_RSET = I_CSET;  updateRSET = 0; }  (actions 3 and 2: Mask=0x06)
  field(CLCK, "(J!=0) ? 0 : (C=1) ? 6 : 0")
  # else  if (updateRSET)  I_RSET = 0;  (action 1: Mask=0x01)
  field(CLCL, "(K!=0) ? 0 : (B=1) ? 1 : 0")
  # Write the resulting bitmask and trigger the desired actions
  field(CLCM, "J | K | L")
  field(OUTM, "_RSET_UpdateActions.SELN")
  field(FLNK, "_RSET_UpdateActions")
# The list of actions used by the RSET_UpdateLogic record which determines
# what (if any) change needs to be made to the RSET value.  Which actions to
# performed is specified by writing a bitmapped value to the SELN field (1 bit
# for each action).
record(seq, "_RSET_UpdateActions")  {
  field(SELM, "Mask")
  # Mask bit 0x01:  Set I_RSET = 0
  field(DOL1, "0")
  field(LNK1, "I_RSET PP")
  # Mask bit 0x02:  Set updateRSET = 0
  field(DOL2, "0")
  field(LNK2, "_updateRSET PP")
  # Mask bit 0x04:  Set I_RSET = I_CSET
  field(DOL3, "I_CSET NPP")
  field(LNK3, "I_RSET PP")
The above approach is modeled on the more procedural approach typically used in high level languages (given a set of conditions, perform all the necessary actions):
if (expression1)
   do a bunch of stuff ...
else
   if (expression2)
     do a different bunch of stuff ...
  else
    do yet a different bunch of stuff ...
However, a more data-driven approach (compute the next state for each variable) could produce the same effect with just a transform record:
   A = (set of nested if/else conditions and expressions)
   B = (possibly overlapping set of nested if/else conditions and expressions)
Having (very successfully) used the later approach heavily in most the embedded controller code I wrote for years, this approach definitely has some advantages.  However, given the vast difference in the tools used to express it in this case  (EPICS records rather than C code), I think the more verbose approach is easier to comprehend, debug, and maintain.  But your mileage may vary.
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
+1
Cheers,
~Ralph
Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
Re: Tips for doing conditional logic in EPICS records Mooney, Tim M. via Tech-talk
Re: Tips for doing conditional logic in EPICS records Ralph Lange via Tech-talk
Prev: releases of devlib2 and mrfioc2 Michael Davidsaver via Tech-talk
Next: Motor record: ACS support Mark Vigder via Tech-talk
Prev: Re: Tips for doing conditional logic in EPICS records Ralph Lange via Tech-talk
Next: StreamDevice question Mark Davis via Tech-talk
