Subject: StreamDevice question
Date: Tue, 28 Apr 2020 14:22:44 -0400
I have what I hope is a quick question about StreamDevice:
For protocols that parse a response with multiple values and use Protocol arguments to specify the names of several records that the values are written to, is there any way to update the STAT and SEVR fields for ALL the affected records, not just the one that called the protocol via its INP field?
If there is no way to get the StreamDevice layer to do this, how about some record logic to do so?
I tried to simply copy the STAT and SEVR values to other records using a seq record processed via an FLNK , but not surprisingly that just generates "Attempt to modify noMod field PV" errors.
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
Prev: Re: Tips for doing conditional logic in EPICS records Davis, Mark via Tech-talk
Next: Synchronization and saving frame rate Matteo C. via Tech-talk
Prev: Re: Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
