Subject: asub to set alarm status for ai record?
From: "Sobhani, Bayan via Tech-talk" <[email protected]>
Date: Wed, 29 Apr 2020 16:43:55 +0000
I am able to set the alarm status of an asub record by doing the following in an asub function:
recGblSetSevr(prec,READ_ALARM,MAJOR_ALARM);
This works for the asub record. Instead of setting the alarm like this for an asub record though, I was wondering if it is possible to set the alarm for an ai record.
Here is my attempt so far. My asub record is defined as:
record(aSub, "$(Sys)$(Dev)T$(N_T)-Elapsed_asub") {
        field(SNAM, "timeElapsed")
        field(INPA, "$(Sys)$(Dev)T$(N_T)-Time")
        field(OUTA, "$(Sys)$(Dev)T$(N_T)-Elapsed PP")
        field(OUTB, "$(Sys)$(Dev)T$(N_T)-I.NSTA")
        field(FTA, "DOUBLE")
        field(FTVA, "DOUBLE")
        field(FTVB, "ENUM")
        field(SCAN, "5 second")
I specified the alarm I am trying to set in OUTB. And then in my asub c file I try to do the following:
*((epicsEnum16*)prec->valb) = READ_ALARM;
I get the following messages in the IOC:
Error (511,511) PV: XF:17ID-CT:FMX{RG:F4}T-I.NSTA error detected in routine: dbPut
Is there any way I can set the alarm status for an ai record from an asub function? I can do it for an asub record, but asub records lack some features that I want from ai records, such as HIGH and HIHI fields.
Alex
Re: asub to set alarm status for ai record? Michael Davidsaver via Tech-talk
Prev: defining debug in modules/libcom/src/osi/epicsGeneralTime.c in epics-base leads to compilation error for TestIoc junkes via Tech-talk
Next: Re: asub to set alarm status for ai record? Michael Davidsaver via Tech-talk
Prev: RE: Synchronization and saving frame rate Mark Rivers via Tech-talk
