Subject: defining debug in modules/libcom/src/osi/epicsGeneralTime.c in epics-base leads to compilation error for TestIoc
To: Tech talk <[email protected]>
Date: Wed, 29 Apr 2020 17:41:11 +0200
defining DEBUG_GENERAL_TIME in modules/libcom/src/osi/epicsGeneralTime.c (line 35)
leads to compilation issue:
Creating dbd file asTestIoc.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../../../../dbd -o asTestIoc.dbd base.dbd asTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../../../../dbd -o asTestIoc_registerRecordDeviceDriver.cpp ../O.Common/asTestIoc.dbd asTestIoc_registerRecordDeviceDriver /home/h1/GSOC/rtems5_epics7/QtC-epics-base
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF asTestIoc_registerRecordDeviceDriver.d asTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF asTest.d ../asTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF seqTest.d ../seqTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF softTest.d ../softTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF asyncSoftTest.d ../asyncSoftTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF compressTest.d ../compressTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF linkInitTest.d ../linkInitTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF linkRetargetLinkTest.d ../linkRetargetLinkTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF recMiscTest.d ../recMiscTest.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF arrayOpTest.d ../arrayOpTest.c
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF dbHeaderTestxx.d ../dbHeaderTestxx.cpp
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include -MM -MF dbHeaderTest.d ../dbHeaderTest.c
../../../../../../bin/linux-x86_64/msi -D -I. -I.. -I../O.Common -I../../../../../../db -o ../O.Common/simmTest.db -S../simmTest.substitutions > simmTest.db.d
simmTest.db.d:1: *** missing separator. Stop.
make[5]: Leaving directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules/database/test/std/rec/O.linux-x86_64'
../../../../../configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[4]: *** [install.linux-x86_64] Error 2
make[4]: Leaving directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules/database/test/std/rec'
../../../configure/RULES_DIRS:84: recipe for target 'std/rec.install' failed
make[3]: *** [std/rec.install] Error 2
make[3]: Leaving directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules/database/test'
../../configure/RULES_DIRS:84: recipe for target 'test.install' failed
make[2]: *** [test.install] Error 2
make[2]: Leaving directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules/database'
../configure/RULES_DIRS:84: recipe for target 'database.install' failed
make[1]: *** [database.install] Error 2
make[1]: Leaving directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules'
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error
The Debug output can be found in the db.d file:
[h1@earth QtC-epics-base (7.0 *+)]$ cat ./modules/database/test/std/rec/O.linux-x86_64/simmTest.db.d
General Time Initialized
Registered time provider 'OS Clock' at 999
../O.Common/simmTest.db: ../simmTestSimple.template \
../simmTestArray.template \
../simmTestHistogram.template \
../simmSetup.db \
../simmSimlFail.db
Heinz
Synchronization and saving frame rate Matteo C. via Tech-talk
Re: Synchronization and saving frame rate Bruno Martins via Tech-talk
Prev: Re: Synchronization and saving frame rate Bruno Martins via Tech-talk
Next: asub to set alarm status for ai record? Sobhani, Bayan via Tech-talk
Next: FW: Synchronization and saving frame rate Engbretson, Mark S. via Tech-talk
