Subject: Re: Synchronization and saving frame rate
From: Bruno Martins via Tech-talk <[email protected]>
To: "Matteo C." <[email protected]>
Date: Wed, 29 Apr 2020 10:44:11 -0400
Hi Matteo,
If you want an upper bound on the rate of images, you can set MinCallbackTime [1] to 1 on the NDPluginStdArray plugin. This means that this plugin will process no faster than 1 second.
If you want exactly 1/10th of the data rate, you can probably use the NDPluginProcess in some configuration that will drop 9 out of 10 arrays. I haven't used it much, so I don't know how to do that exactly.
Bruno
On Wed, Apr 29, 2020 at 10:21 AM Matteo C. via Tech-talk <[email protected]> wrote:
Hi everyone,
hope you are all safe and sound.
I need some help to solve a synchronization problem using Areadetector and its Plug-ins.
We would need to get different pieces of data from a camera and a Picoscope (Oscilloscope). The idea is to get data from the Picoscope and the average of the image at a certain rate, and the image itself at a 10th of this rate. I was wondering if there's an option to save via JPEG or HDF5 (which take care also of the time synchronization of the two) at different rates than the rate acquisition of the StdArray: for example if the frame rates of the camera and the Picoscope are at 10frames/s (we want an image for every second, and we want 10 sample of picoscope/average image per image), the image is saved every second and the picoscope/average of image 10 times per second. The reason is that we do not need that many images but mainly we are interested in the Picoscope and image average and we want to save some space.
Thank you,
Kind regards,
Matteo Ciarchi
defining debug in modules/libcom/src/osi/epicsGeneralTime.c in epics-base leads to compilation error for TestIoc junkes via Tech-talk
Synchronization and saving frame rate Matteo C. via Tech-talk
Prev: Re: Synchronization and saving frame rate Mark Rivers via Tech-talk
Next: defining debug in modules/libcom/src/osi/epicsGeneralTime.c in epics-base leads to compilation error for TestIoc junkes via Tech-talk
