1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: FW: Synchronization and saving frame rate
From: "Engbretson, Mark S. via Tech-talk" <[email protected]>
To: "[email protected] ([email protected])" <[email protected]>
Date: Mon, 4 May 2020 13:01:49 +0000
Sent: Monday, May 4, 2020 2:33 AM
To: Engbretson, Mark S. <[email protected]>
Subject: R: Synchronization and saving frame rate
Dear everyone,
thank you for the numerous and useful answers.
Probably Mr. Engbretson answer is the most suited for what I need: it allows to obtain directly what I need, i.e. 1 images for every 10 frames, even if it doesn't seem the cleanest way. I'll try that.
Now another question comes to my mind: since in the other 9 frames there is information I need (namely the average of the array), would it be possible through the scatter plugin to send one frame with the total array to say a JPEG plugin to save directly images, and the other 9 with the attributes I want to save and WITHOUT the image array to a HDF5 file to save these attributes?
Thank you again.
Kind regards,
Matteo Ciarchi
Da: Engbretson, Mark S. <[email protected]>
Inviato: mercoledì 29 aprile 2020 17:02
A: Matteo C. <[email protected]>
Oggetto: RE: Synchronization and saving frame rate
Wouldn’t a quick-and-dirty way to fake this effect be by using the NDPluginScatter plugin to fan out those 10 images , only 1 of which actually generates a file and the other 10 just go to something like the nullfileplugin so that no file is actually generated?
From: Tech-talk <[email protected]> On Behalf Of Matteo C. via Tech-talk
Sent: Wednesday, April 29, 2020 9:21 AM
To: tech-talk <[email protected]>
Subject: Synchronization and saving frame rate
Hi everyone,
hope you are all safe and sound.
I need some help to solve a synchronization problem using Areadetector and its Plug-ins.
We would need to get different pieces of data from a camera and a Picoscope (Oscilloscope). The idea is to get data from the Picoscope and the average of the image at a certain rate, and the image itself at a 10th of this rate. I was wondering if there's an option to save via JPEG or HDF5 (which take care also of the time synchronization of the two) at different rates than the rate acquisition of the StdArray: for example if the frame rates of the camera and the Picoscope are at 10frames/s (we want an image for every second, and we want 10 sample of picoscope/average image per image), the image is saved every second and the picoscope/average of image 10 times per second. The reason is that we do not need that many images but mainly we are interested in the Picoscope and image average and we want to save some space.
Thank you,
Kind regards,
Matteo Ciarchi
RE: Synchronization and saving frame rate Mark Rivers via Tech-talk
Synchronization and saving frame rate Matteo C. via Tech-talk
Prev: EPICS Qt 3.7.3 [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Next: RE: Synchronization and saving frame rate Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: defining debug in modules/libcom/src/osi/epicsGeneralTime.c in epics-base leads to compilation error for TestIoc junkes via Tech-talk
