Subject: RE: asub to set alarm status for ai record?
From: "Sobhani, Bayan via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Apr 2020 18:03:46 +0000
Thanks Kay and Michael. I tried this out and it works for what I am trying to do.
Alex
-----Original Message-----
Sent: Wednesday, April 29, 2020 1:01 PM
To: Sobhani, Bayan <[email protected]>; [email protected]
Subject: Re: asub to set alarm status for ai record?
Alarm severity is usually propagated along with a value by adding the 'MS' (Maximize Severity) link modifier.  eg.
>         field(OUTB, "$(Sys)$(Dev)T$(N_T)-I PP MS")
Will push a value to "$(Sys)$(Dev)T$(N_T)-I" and copy the alarm severity of the originating (aSub) record.
On 4/29/20 9:43 AM, Sobhani, Bayan via Tech-talk wrote:
> I am able to set the alarm status of an asub record by doing the following in an asub function:
> recGblSetSevr(prec,READ_ALARM,MAJOR_ALARM);
> This works for the asub record. Instead of setting the alarm like this for an asub record though, I was wondering if it is possible to set the alarm for an ai record.
> Here is my attempt so far. My asub record is defined as:
> record(aSub, "$(Sys)$(Dev)T$(N_T)-Elapsed_asub") {
>         field(SNAM, "timeElapsed")
>         field(INPA, "$(Sys)$(Dev)T$(N_T)-Time")
>         field(OUTA, "$(Sys)$(Dev)T$(N_T)-Elapsed PP")
>         field(OUTB, "$(Sys)$(Dev)T$(N_T)-I.NSTA")
>         field(FTA, "DOUBLE")
>         field(FTVA, "DOUBLE")
>         field(FTVB, "ENUM")
>         field(SCAN, "5 second")
> I specified the alarm I am trying to set in OUTB. And then in my asub c file I try to do the following:
> *((epicsEnum16*)prec->valb) = READ_ALARM;
> I get the following messages in the IOC:
> Error (511,511) PV: XF:17ID-CT:FMX{RG:F4}T-I.NSTA error detected in
> routine: dbPut
> Is there any way I can set the alarm status for an ai record from an asub function? I can do it for an asub record, but asub records lack some features that I want from ai records, such as HIGH and HIHI fields.
> Alex
asub to set alarm status for ai record? Sobhani, Bayan via Tech-talk
Re: asub to set alarm status for ai record? Michael Davidsaver via Tech-talk
Prev: Re: asub to set alarm status for ai record? Michael Davidsaver via Tech-talk
Next: releases of devlib2 and mrfioc2 Michael Davidsaver via Tech-talk
