Mark,
There are two companies named ACS.
The web page for the ACS that makes the SPI-8 (as well as the MCB-4B and
step-pak motor drivers) is here:
http://www.acsmotion.com/ACS_Step-Pak_Catalog.htm
There is support for the MCB-4B, but NOT the SPI-8 in this driver repo:
https://github.com/epics-motor/motorAcs
I'm not aware of any EPICS support for the SPI-8.
The web for the other company named ACS is here:
https://www.acsmotioncontrol.com/
Support for legacy ACS Motion Control controllers is here:
https://github.com/epics-motor/motorAcsTech80
Keenan Lang has developed some motor support for newer controllers from
ACS Motion Control, but I don't remember where that repo is. It hasn't
been added to epics-motors yet.
Kevin
On 4/30/20 10:47 AM, Mark Vigder via Tech-talk wrote:
> Greetings
> I haven't used EPICS for a while but am helping out a local facility get
> a new system up and running using EPICS. They want to use The Advanced
> Control System (ACS) motor control. The controller is the SPI-8
> 8-channel Indexer/Controller Module. Is this supported by the Motor
> record? There are a couple of motor drivers for ACS distributed with the
> EPICS motor record; I assume if one is applicable it is the
> motorAcsTech80. Will this work with the SPI-8 Indexer Module from ACS?
> The last revision date on the manual they gave me is 2008 so they may be
> using an old controller.
> Thanks for any help
> Mark
> Mark Vigder
> TVB Associates
- Re: Motor record: ACS support Mark Vigder via Tech-talk
- Motor record: ACS support Mark Vigder via Tech-talk
Wago 750 support Goetze, Kurt via Tech-talk
Re: Wago 750 support John Dobbins via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
