1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Motor record: ACS support
From: Mark Vigder via Tech-talk <[email protected]>
To: "Peterson, Kevin M." <[email protected]>
Date: Thu, 30 Apr 2020 13:37:06 -0400
Kevin
Wow, two companies with the same name. No wonder I was getting confused.
I went to the ACS company site that makes the SPI-8. Their site states the following multi-axis controllers as having EPICS support:
    SPI-MAXnet-8000
    MCR-4 / MCR-8
    MCB-4B
Is the above information correct, and if so would that support all be in https://github.com/epics-motor/motorAcs?
The ACS website does not claim EPICS support  for the SPI-8.
On Thu, Apr 30, 2020 at 12:19 PM Peterson, Kevin M. <[email protected]> wrote:
Mark,
There are two companies named ACS.
The web page for the ACS that makes the SPI-8 (as well as the MCB-4B and
step-pak motor drivers) is here:
   http://www.acsmotion.com/ACS_Step-Pak_Catalog.htm
There is support for the MCB-4B, but NOT the SPI-8 in this driver repo:
I'm not aware of any EPICS support for the SPI-8.
The web for the other company named ACS is here:
   https://www.acsmotioncontrol.com/
Support for legacy ACS Motion Control controllers is here:
   https://github.com/epics-motor/motorAcsTech80
Keenan Lang has developed some motor support for newer controllers from
ACS Motion Control, but I don't remember where that repo is.  It hasn't
been added to epics-motors yet.
Kevin
On 4/30/20 10:47 AM, Mark Vigder via Tech-talk wrote:
> Greetings
> I haven't used EPICS for a while but am helping out a local facility get
> a new system up and running using EPICS. They want to use The Advanced
> Control System (ACS) motor control. The controller is the SPI-8
> 8-channel Indexer/Controller Module. Is this supported by the Motor
> record? There are a couple of motor drivers for ACS distributed with the
> EPICS motor record; I assume if one is applicable it is the
> motorAcsTech80. Will this work with the SPI-8 Indexer Module from ACS?
> The last revision date on the manual they gave me is 2008 so they may be
> using an old controller.
> Thanks for any help
> Mark
> Mark Vigder
> TVB Associates
Re: Motor record: ACS support Mark Rivers via Tech-talk
Motor record: ACS support Mark Vigder via Tech-talk
Re: Motor record: ACS support Peterson, Kevin M. via Tech-talk
Prev: Re: Wago 750 support John Dobbins via Tech-talk
Next: Re: Motor record: ACS support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Motor record: ACS support Peterson, Kevin M. via Tech-talk
