Hi Mark,
SPI-MAXnet-8000 support is in motorOmsAsyn.
MCB-4B support is in motorAcs.
I am not sure about the MCR-4 and MCR-8 but I think those are just packaged versions of the MCB-4B, so the support would be in motorAcs.
From: Tech-talk <[email protected]> on behalf of Mark Vigder via Tech-talk <[email protected]>
Sent: Thursday, April 30, 2020 12:37 PM
To: Peterson, Kevin M.
Cc: [email protected]
Subject: Re: Motor record: ACS support
Kevin
Wow, two companies with the same name. No wonder I was getting confused.
I went to the ACS company site that makes the SPI-8. Their site states the following multi-axis controllers as having EPICS support:
SPI-MAXnet-8000
MCR-4 / MCR-8
MCB-4B
Is the above information correct, and if so would that support all be in https://github.com/epics-motor/motorAcs?
The ACS website does not claim EPICS support for the SPI-8.
On Thu, Apr 30, 2020 at 12:19 PM Peterson, Kevin M. <[email protected]<mailto:[email protected]>> wrote:
Mark,
There are two companies named ACS.
The web page for the ACS that makes the SPI-8 (as well as the MCB-4B and
step-pak motor drivers) is here:
http://www.acsmotion.com/ACS_Step-Pak_Catalog.htm
There is support for the MCB-4B, but NOT the SPI-8 in this driver repo:
I'm not aware of any EPICS support for the SPI-8.
The web for the other company named ACS is here:
https://www.acsmotioncontrol.com/
Support for legacy ACS Motion Control controllers is here:
https://github.com/epics-motor/motorAcsTech80
Keenan Lang has developed some motor support for newer controllers from
ACS Motion Control, but I don't remember where that repo is. It hasn't
been added to epics-motors yet.
Kevin
On 4/30/20 10:47 AM, Mark Vigder via Tech-talk wrote:
> Greetings
> I haven't used EPICS for a while but am helping out a local facility get
> a new system up and running using EPICS. They want to use The Advanced
> Control System (ACS) motor control. The controller is the SPI-8
> 8-channel Indexer/Controller Module. Is this supported by the Motor
> record? There are a couple of motor drivers for ACS distributed with the
> EPICS motor record; I assume if one is applicable it is the
> motorAcsTech80. Will this work with the SPI-8 Indexer Module from ACS?
> The last revision date on the manual they gave me is 2008 so they may be
> using an old controller.
> Thanks for any help
> Mark
> Mark Vigder
> TVB Associates
- Re: Motor record: ACS support Arms, Dohn A. via Tech-talk
- Re: Motor record: ACS support Peterson, Kevin M. via Tech-talk
- Motor record: ACS support Mark Vigder via Tech-talk
- Re: Motor record: ACS support Mark Vigder via Tech-talk
Re: Motor record: ACS support Mark Rivers via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
