The SPI-MAXnet-8000 doesn't work well and I don't recommend it. I have
had nothing but trouble with the two I've had the misfortune of
supporting.
The network stack of the MAXnet controller was not robust; connecting
the controller to the network via ethernet would result in it locking up
after only a few minutes. A power-cycle was required to be able to
reconnect to the controller.
The pinout of the serial port in the documentation was that of the
header on the board, NOT the RJ45 connection, if I remember correctly.
This is what I determined the pinout to be:
RJ45 Function DB9
1 nc 1
3 RXD 2
5 TXD 3
7 nc 4
8 GND 5
2 nc 6
4 RTS 7
6 CTS 8
X nc 9
And most importantly the MAXnet does not use the same line driver as the
MAVv board, which has internal filters. The MAXnet controller is very
susceptible to noise on the limit lines. The integration of the MAXnet
controller into the SPI-MAXnet-8000 package makes it difficult to add
filters.
Kevin
On 4/30/20 1:32 PM, Mark Rivers wrote:
> Hi Mark,
> SPI-MAXnet-8000 support is in motorOmsAsyn.
> MCB-4B support is in motorAcs.
> I am not sure about the MCR-4 and MCR-8 but I think those are just packaged versions of the MCB-4B, so the support would be in motorAcs.
> Mark
- Motor record: ACS support Mark Vigder via Tech-talk
- Re: Motor record: ACS support Peterson, Kevin M. via Tech-talk
- Re: Motor record: ACS support Mark Vigder via Tech-talk
- Re: Motor record: ACS support Mark Rivers via Tech-talk
Bug report: EPICS base 7.0.3.1, deadlock Jonas Nilsson via Tech-talk
EtherNet/IP Simulator Shen, Guobao via Tech-talk
<2020>
2025
2026
Re: Motor record: ACS support Arms, Dohn A. via Tech-talk
Wago 750 support Goetze, Kurt via Tech-talk
<2020>
2025
2026
