1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter
From: Carsten Winkler via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 6 May 2020 16:22:11 +0200
I successfully compiled Epics 7.0.3.1 for Windows 7 x64. When I start softIoc.exe without dbd-parameter (-D), everything is fine. But when I specify the path for the same dbd file, I get an illegal option error.
(I wanna move the dbd file for a client application.)
What do I wrong?
Best regards
Carsten
C:\>"C:\base-7.0.3.1\bin\windows-x64\softIoc.exe" -D "C:\base-7.0.3.1\dbd\softIoc.dbd" -d "\DemoIOC\db\demo.db"
C:\base-7.0.3.1\bin\windows-x64\softIoc.exe: illegal option -- D
Usage: C:\base-7.0.3.1\bin\windows-x64\softIoc.exe [-D softIoc.dbd] [-h] [-S] [-s] [-a ascf]
[-m macro=value,macro2=value2] [-d file.db]
[-x prefix] [st.cmd]
    -D <dbd>  If used, must come first. Specify the path to the softIoc.dbdfile.        The compile-time install location is saved in the binary as a default.
    -h  Print this mesage and exit.
    -S  Prevents an interactive shell being started.
    -s  Previously caused a shell to be started.  Now accepted and ignored.
    -a <acf>  Access Security configuration file.  Macro substitution is
        performed.
    -m <MAC>=<value>,... Set/replace macro definitions used by subsequent -d and
        -a.
    -d <db>  Load records from file (dbLoadRecords).  Macro substitution is
        performed.
    -x <prefix>  Load softIocExit.db.  Provides a record "<prefix>:exit".
        Put 0 to exit with success, or non-zero to exit with an error.
Any number of -m and -d arguments can be interspersed; the macros are applied
to the following .db files.  Each later -m option causes earlier macros to be
discarded.
A st.cmd file is optional.  If any databases were loaded the st.cmd file will
be run *after* iocInit.  To perform iocsh commands before iocInit, all database
loading must be performed by the script itself, or by the user from the
interactive IOC shell.
Compiled-in path to softIoc.dbd is:
        C:\base-7.0.3.1\bin\windows-x64\../../dbd/softIoc.dbd
Unknown argument: -?
C:\>
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Michael Davidsaver via Tech-talk
Prev: EPICS DB file automation for PLC from spreadsheet Shen, Guobao via Tech-talk
Next: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: EPICS DB file automation for PLC from spreadsheet Lucas Russo via Tech-talk
