Subject: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Carsten Winkler <[email protected]>
Cc: [email protected]
Date: Wed, 6 May 2020 10:15:06 -0700
On 5/6/20 7:22 AM, Carsten Winkler via Tech-talk wrote:
> Hi,
> I successfully compiled Epics 7.0.3.1 for Windows 7 x64. When I start softIoc.exe without dbd-parameter (-D), everything is fine. But when I specify the path for the same dbd file, I get an illegal option error.
> (I wanna move the dbd file for a client application.)
> What do I wrong?
Nothing.  The bad news is that this was a mistake with 7.0.3.1
which has since been fixed.  The good news is that -D is no longer needed
to find softIoc.dbd in its default location ../../dbd/softIoc.dbd
relative to softIoc.exe.  So in your example you should be able to omit '-D'.
https://epics.anl.gov/tech-talk/2019/msg01822.php
> Best regards
> Carsten
> C:\>"C:\base-7.0.3.1\bin\windows-x64\softIoc.exe" -D "C:\base-7.0.3.1\dbd\softIoc.dbd" -d "\DemoIOC\db\demo.db"
> *C:\base-7.0.3.1\bin\windows-x64\softIoc.exe: illegal option -- D*
> Usage: C:\base-7.0.3.1\bin\windows-x64\softIoc.exe [-D softIoc.dbd] [-h] [-S] [-s] [-a ascf]
> [-m macro=value,macro2=value2] [-d file.db]
> [-x prefix] [st.cmd]
>     -D <dbd>  If used, must come first. Specify the path to the softIoc.dbdfile.        The compile-time install location is saved in the binary as a default.
>     -h  Print this mesage and exit.
>     -S  Prevents an interactive shell being started.
>     -s  Previously caused a shell to be started.  Now accepted and ignored.
>     -a <acf>  Access Security configuration file.  Macro substitution is
>         performed.
>     -m <MAC>=<value>,... Set/replace macro definitions used by subsequent -d and
>         -a.
>     -d <db>  Load records from file (dbLoadRecords).  Macro substitution is
>         performed.
>     -x <prefix>  Load softIocExit.db.  Provides a record "<prefix>:exit".
>         Put 0 to exit with success, or non-zero to exit with an error.
> Any number of -m and -d arguments can be interspersed; the macros are applied
> to the following .db files.  Each later -m option causes earlier macros to be
> discarded.
> A st.cmd file is optional.  If any databases were loaded the st.cmd file will
> be run *after* iocInit.  To perform iocsh commands before iocInit, all database
> loading must be performed by the script itself, or by the user from the
> interactive IOC shell.
> Compiled-in path to softIoc.dbd is:
>         C:\base-7.0.3.1\bin\windows-x64\../../dbd/softIoc.dbd
> Unknown argument: -?
> C:\>
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Johnson, Andrew N. via Tech-talk
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Prev: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Next: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Johnson, Andrew N. via Tech-talk
