Subject: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter
From: Carsten Winkler via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Thu, 7 May 2020 16:24:44 +0200
Thank you! I've patched softIoc.cpp, and now all is fine.
Am 06.05.20 um 19:15 schrieb Michael Davidsaver:
On 5/6/20 7:22 AM, Carsten Winkler via Tech-talk wrote:
I successfully compiled Epics 7.0.3.1 for Windows 7 x64. When I start softIoc.exe without dbd-parameter (-D), everything is fine. But when I specify the path for the same dbd file, I get an illegal option error.
(I wanna move the dbd file for a client application.)
What do I wrong?
Nothing.  The bad news is that this was a mistake with 7.0.3.1
which has since been fixed.  The good news is that -D is no longer needed
to find softIoc.dbd in its default location ../../dbd/softIoc.dbd
relative to softIoc.exe.  So in your example you should be able to omit '-D'.
https://epics.anl.gov/tech-talk/2019/msg01822.php
Best regards
Carsten
C:\>"C:\base-7.0.3.1\bin\windows-x64\softIoc.exe" -D "C:\base-7.0.3.1\dbd\softIoc.dbd" -d "\DemoIOC\db\demo.db"
*C:\base-7.0.3.1\bin\windows-x64\softIoc.exe: illegal option -- D*
Usage: C:\base-7.0.3.1\bin\windows-x64\softIoc.exe [-D softIoc.dbd] [-h] [-S] [-s] [-a ascf]
[-m macro=value,macro2=value2] [-d file.db]
[-x prefix] [st.cmd]
     -D <dbd>  If used, must come first. Specify the path to the softIoc.dbdfile.        The compile-time install location is saved in the binary as a default.
     -h  Print this mesage and exit.
     -S  Prevents an interactive shell being started.
     -s  Previously caused a shell to be started.  Now accepted and ignored.
     -a <acf>  Access Security configuration file.  Macro substitution is
         performed.
     -m <MAC>=<value>,... Set/replace macro definitions used by subsequent -d and
         -a.
     -d <db>  Load records from file (dbLoadRecords).  Macro substitution is
         performed.
     -x <prefix>  Load softIocExit.db.  Provides a record "<prefix>:exit".
         Put 0 to exit with success, or non-zero to exit with an error.
Any number of -m and -d arguments can be interspersed; the macros are applied
to the following .db files.  Each later -m option causes earlier macros to be
discarded.
A st.cmd file is optional.  If any databases were loaded the st.cmd file will
be run *after* iocInit.  To perform iocsh commands before iocInit, all database
loading must be performed by the script itself, or by the user from the
interactive IOC shell.
Compiled-in path to softIoc.dbd is:
         C:\base-7.0.3.1\bin\windows-x64\../../dbd/softIoc.dbd
Unknown argument: -?
C:\>
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Postadresse:
D-14109 Berlin
Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Michael Davidsaver via Tech-talk
Prev: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Johnson, Andrew N. via Tech-talk
Next: Re: EPICS DB file automation for PLC from spreadsheet Lucas Russo via Tech-talk
Next: Announcing epics-base 7.0.3.1 on conda-forge Benjamin Bertrand via Tech-talk
