Dear all, I wrote a power control IOC. The function of the power supply is realized, but when I start the IOC, it appears in cycles “Timeout after reading 27 bytes…”,eg:
(base) [root@localhost iocelexample]# ./pulse_el.cmd #!../../bin/linux-x86_64/elexample < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocelexample") epicsEnvSet("TOP","/home/EPICS/elCtrl") epicsEnvSet("EPICS_BASE","/home/EPICS/base-3.14.12") epicsEnvSet("ASYN","/home/EPICS/app/asyn4-17") epicsEnvSet("STREAM","/home/EPICS/app/stream") cd /home/EPICS/elCtrl dbLoadDatabase "dbd/elexample.dbd" elexample_registerRecordDeviceDriver pdbbase
#where can protocols be located? epicsEnvSet "STREAM_PROTOCOL_PATH", "."
#the device name is "pulse" #输入IP和端口号 #dbLoadTemplate "db/userHost.substitutions" #dbLoadRecords "db/dbSubExample.db", "user=rootHost" drvAsynIPPortConfigure "pulse_el", "172.17.126.22:8080" #drvAsynIPPortConfigure "pulse_el", "192.168.157.1:8080" #drvAsynIPPortConfigure "pulse_el", "192.168.5.8:30000" asynSetTraceMask("pulse_el",-1,0x1) dbLoadRecords "db/pulse_el.db","p=PulseEl" epicsEnvSet("EPICS_CA_SERVER_PORT","5064") epicsEnvSet("EPICS_CA_REPEATER_PORT", "5065") epicsEnvSet("EPICS_CA_AUTO_ADDR_LIST", "YES") epicsEnvSet("EPICS_CA_ADDR_LIST", "192.168.6.17:5066") cd /home/EPICS/elCtrl/iocBoot/iocelexample iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12 $Date: Wed 2010-11-24 14:50:38 -0600$ ## EPICS Base built Jan 16 2020 ############################################################################ iocRun: All initialization complete
epics> 2020/05/11 07:54:24.626883 pulse_el PulseEl:IMon: Timeout after reading 27 bytes "...<01>*<00>�<01><00><00><00>�@IB3O<9c>@<00><00><ff><ff>" 2020/05/11 07:54:25.628253 pulse_el PulseEl:VMon: Timeout after reading 27 bytes "...<01>*<00>�<01><00><00><00>�@IB3O<9c>@<00><00><ff><ff>" 2020/05/11 07:54:27.629832 pulse_el PulseEl:IMon: Timeout after reading 27 bytes "...<01>*<00>�<01><00><00><00>�@IB3O<9c>@<00><00><ff><ff>" 2020/05/11 07:54:29.633361 pulse_el PulseEl:VMon: Timeout after reading 27 bytes "...<01>*<00>�<01><00><00><00>�@IB3O<9c>@<00><00><ff><ff>"
The command is hexadecimal, when sending a hexadecimal command to the power supply:FF FF 00 00 0E 00 04 01 2A AA 00 00 FF FF , received the power back reading command:FFFF00001B0004012A00AA01000000DC404942334F9C400000FFFF My record file:
record (ai, "$(p):IMon") { field (DTYP, "stream") field (INP, "@pulse_el.proto Read_IMon pulse_el") field (SCAN, "2 second") } record (ai, "$(p):VMon") { field (DTYP, "stream") field (INP, "@pulse_el.proto Read_VMon pulse_el") field (SCAN, "2 second") } My proto file: Read_IMon { out "\xFF\xFF\x00\x00\x0E\x00\x04\x01\x2A\xAA\x00\x00\xFF\xFF"; in "%*15r%(/$p:IMon)#R%*8r"; #in "%*15r%(/$p:IMon)#R%(/$p:VMon)#R%*4r"; MaxInput = 28; ExtralInput = Error; } Read_VMon { out "\xFF\xFF\x00\x00\x0E\x00\x04\x01\x2A\xAA\x00\x00\xFF\xFF"; in "%*19r%(/$p:VMon)#R%*4r"; MaxInput = 28; ExtralInput = Error; }
If you comment out this sentence ”MaxInput=28;” there will be no errors like “timeout after …”, but PV: PulseEl:IMon and PulseEl:VMon value is 0, which are not the correct values (normal values: PulseEl:IMon is 50.3133 and PulseEl:VMon is 4.88467). On the official website, about InTerminal:
“If a device has different terminators for input and output, use this for the input terminator. If no Terminator or InTerminator is defined, the underlying driver may use its own terminator settings. If InTerminator = "", a read timeout is not an error but a valid input termination.”
So in this case, timeout is not an error, but because this error will occur repeatedly, if there are other errors, they may be washed away, resulting in the failure to find the problem. I wonder if there are other ways to avoid this error, and get two valid normal values.
Thanks very much and best wishes! JiaosaiLi, IMPCAS
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
