1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Yendell, Gary (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 May 2020 15:58:08 +0000
Thanks!  That is helpful.
Kevin
On 5/21/20 9:02 AM, Yendell, Gary (DLSLtd,RAL,LSCI) wrote:
> Hi Kevin,
> I have added a section to the docs to demonstrate the difference PVI
> would make in terms of ongoing development:
> https://pvi.readthedocs.io/en/latest/drivers.html#ongoing-development
> I think the key thing to note is that if you have an existing module,
> you do not need to hand construct the YAML file. You can run a one time
> script to generate it from the existing template file(s).
> Cheers,
> Gary
PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Peterson, Kevin M. via Tech-talk
Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Mark Rivers via Tech-talk
