Subject: Re: Displaying string Waveform in CaQtDM
To: EPICS tech-talk <[email protected]>
Date: Thu, 21 May 2020 17:08:00 -0500
Related question...
Is there any reason this is so small?
caQtDM_Lib/src/knobData.h:
  #define STRING_EXCHANGE_SIZE 8192
I'd really like to dump a configuration file into a string.  But as it stands, the multilinestring caQtDM widget will only display the first 8k characters.
I've shown that I can fix it by bumping this up a lot.  Any reason to keep it so small?
Paul
On Wed, May 20, 2020 at 3:15 PM Paul Nord <[email protected]> wrote:
Thank you Jarda!!
I've been banging my head on this for a couple of days now.
Below is a complete working ioc.
Paul
PYTHON FILE
#!/usr/local/epics/modules/pythonIoc/pythonIoc
from softioc import builder, softioc
import numpy as np
import pandas
d = {'col1': [1, 2], 'col2': [3, 4]}
x = pandas.DataFrame(d)
x_string = x.to_string()
a_PV = builder.WaveformOut("name",length=len(x_string),FTVL="CHAR")
a_PV.set(np.array([ord(i) for i in x_string]))
print(a_PV.get().tostring())
builder.LoadDatabase()
softioc.iocInit()
softioc.interactive_ioc(globals())
caQtDM FILE
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
 <class>Form</class>
 <widget class="caFrame" name="Form">
  <property name="geometry">
   <rect>
    <x>0</x>
    <y>0</y>
    <width>400</width>
    <height>300</height>
   </rect>
  </property>
  <property name="windowTitle">
   <string>Form</string>
  </property>
  <widget class="caMultiLineString" name="camultilinestring">
    <rect>
     <x>30</x>
     <y>30</y>
     <width>311</width>
     <height>191</height>
    </rect>
   </property>
   <property name="channel" stdset="0">
    <string notr="true">name</string>
   </property>
  </widget>
 </widget>
 <customwidgets>
  <customwidget>
   <class>caFrame</class>
   <extends>QFrame</extends>
   <header>caFrame</header>
   <container>1</container>
  </customwidget>
  <customwidget>
   <class>caMultiLineString</class>
   <extends>QPlainTextEdit</extends>
   <header>caMultiLineString</header>
  </customwidget>
 </customwidgets>
 <resources/>
 <connections/>
</ui>
Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
Re: Displaying string Waveform in CaQtDM Mark Rivers via Tech-talk
Re: Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
RE: Displaying string Waveform in CaQtDM Mark Rivers via Tech-talk
Re: Displaying string Waveform in CaQtDM Johnson, Andrew N. via Tech-talk
Re: Displaying string Waveform in CaQtDM Jaroslav Adam via Tech-talk
Prev: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Peterson, Kevin M. via Tech-talk
Next: anyone ever crosscompile pvaPy? Peter Milne via Tech-talk
Prev: Re: Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
Next: Re: Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
