1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug"
From: Carsten Winkler via Tech-talk <[email protected]>
To: "Heesterman, Peter J" <[email protected]>, "Johnson, Andrew N." <[email protected]>, "'[email protected]'" <[email protected]>, <[email protected]>
Date: Mon, 25 May 2020 10:50:55 +0200
Hi there,
up to now "caLabDisconnect.vi" is optional. The success of the CA Lab is the simple black box concept. You can use "caLabGet.vi" whenever you want without any separate "connect.vi" nor "disconnect.vi". I would like to retain this concept. Therefore, the additional function with "ca_task_exit()" is no solution in the CA Lab case.
Thanks to the hint from Michael and the friendly request from Freddi, I followed up the concept GetModuleHandleEx() with GET_MODULE_HANDLE_EX_FLAG_PIN. And this seems to be the key.
Now I can use my old code without any deadlocks. LabVIEW can open and close VIs with CA Lab repeatedly without problems. But LabVIEW must now be closed completely to get rid of CA Lab and Channel Access. I don't think that should be a problem.
Is there a similar solution (prevent unload library) for Linux?
Best regards
Carsten
Am 21.05.20 um 11:56 schrieb Heesterman, Peter J:
Hi Carsten,
See https://stackoverflow.com/questions/35828004/waitforsingleobject-for-thread-object-does-not-work-in-dll-unload
Basically calling ca_context_destroy()  from within DLLMain() is not an option, as it will cause deadlock.
It will need to be explicitly invoked - prior to DLL unload -  from within application code.
This might be from within your caLabDisconnect.vi?
If this is not an option, a more complex approach (as described in the article) involving 2 DLLs is possible.
But this more complex and I haven’t tested that, to date.
I changed your test code like below, and it exits normally.
All the best,
Peter.
#include <windows.h>
#include <iostream>
#include <epicsExit.h>
#include "myCaLib.h"
int main()
       HINSTANCE hinstLib;
       BOOL fFreeResult;
       hinstLib = LoadLibrary(TEXT("myCaLib.dll"));
       if (hinstLib == NULL) {
              std::cout << "myCaLib.dll not found" << std::endl;
              return 1;
       std::cout << "library loaded; hit ENTER to unload" << std::endl;
       getchar();
       myCaLibClosing();
       fFreeResult = FreeLibrary(hinstLib);
       std::cout << "bye" << std::endl;
       return 0;
// myCaLib.cpp : Defines the exported functions for the DLL application.
#include <iostream>
#include <cadef.h>
#define epicsExportSharedSymbols
void myCaLibClosing()
       ca_task_exit();
BOOLEAN WINAPI DllMain(HINSTANCE hDllHandle, DWORD nReason, LPVOID
       Reserved) {
       switch (nReason)
       case DLL_PROCESS_ATTACH: {
              int32_t iResult =
                     ca_context_create(ca_enable_preemptive_callback);
              if (iResult != ECA_NORMAL) {
                     std::cout << "Error: Could not create any instance of Channel Access." << std::endl;
                     return 0;
              std::cout << "New instance of Channel Access context." << std::endl;
              std::cout << ca_context_status(ca_current_context(), 1) << std::endl;
              break;
       case DLL_PROCESS_DETACH: {
              std::cout << "detach process ... " << std::endl;
              break;
       return 1;
Sent: 19 May 2020 10:40
To: Johnson, Andrew N. <[email protected]>; Carsten Winkler <[email protected]>
Subject: RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug"
Hi Andrew, Carsten,
I may be able to help with this, if that would be beneficial.
I myself use caLab quite extensively.
Cheers,
Peter.
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: 18 May 2020 18:57
To: Carsten Winkler <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Hi Carsten,
I’m not aware of anything that has actually been added to libCom or libca recently to prevent a completely shutdown; are you saying that you used to be able to unload the CA library and you can’t now? I don’t believe this has ever been possible (which is probably what Michael is also going by), but I might be wrong – please let us know what version of Base you were using if and when you could do that.
If it’s your requirement that has changed we would be happy to advise someone how to work out what needs to be modified to allow the complete unloading that you’re looking for, but I can’t promise that we’ll have core developer effort available to do the actual investigation and any development needed (we all manage our own time and have our own priorities controlled by our employers, so I can’t speak for the others).
- Andrew
On May 18, 2020, at 12:21 PM, Carsten Winkler via Tech-talk <[email protected]> wrote:
thank you for your answer. This are bad news for our community. Many users are waiting for an EPICS Base upgrade for the Open Source software CaLab (interface beween LabVIEW and EPICS).
Best reganrds
Carsten
Am 18.05.2020 um 18:27 schrieb Michael Davidsaver:
libca and especially libCom can't be completely shutdown, and therefore
can't be safely unloaded.
On 5/18/20 8:34 AM, Carsten Winkler via Tech-talk wrote:
for a project I need to load and unload the Channel Access context in a
shared library. Loading is no problem but unloading. It always fails
during ca_context_destroy() function.
Here is my demo code:
main.cpp (most simple case for a bigger project where it's necessary to
load and unload different shared libraries at runtime without
terminating main application)
#include <iostream>
int main()
    HINSTANCE hinstLib;
    BOOL fFreeResult;
        return 1;
    getchar();
    return 0;
_______________________________________________________________________
myCaLib.cpp (most simple shared library with no functions except
creating and releasing the Channel Access context)
#include <iostream>
#include <cadef.h>
Reserved) {
    switch (nReason)
            int32_t iResult =
                return 0;
std::endl;
std::endl;
            break;
            ca_context_destroy();
            break;
    return 1;
build at command line at Windows 7 64 bit
%comspec% /k "C:\Program Files (x86)\Microsoft Visual
Studio\2019\Community\VC\Auxiliary\Build\vcvars64.bat"
set base=C:\base-7.0.x            <== directory of nightly build or
stable EPICS BASE 7.0 (built with "EPICS_HOST_ARCH=windows-x64")
cd C:\test_case\                       <== directory of our test sources
main.cpp and myCaLib.cpp
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -EHsc -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -I%base%/include/compiler/msvc
-I%base%/include/os/WIN32 -I%base%/include -c main.cpp myCaLib.cpp
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release -version:7.0 -MACHINE:X64 -libpath:%base%\lib\windows-x64
-out:myCaLib.dll -implib:myCaLib.lib myCaLib.obj ca.lib Com.lib
link -nologo -LTCG -incremental:no -opt:ref -release -version:7.0
-MACHINE:X64 -out:test.exe main.obj
set path=%base%\bin\windows-x64;%path%
test.exe
test.exe will freeze because it hangs on ca_context_destroy()
I need any solution for this case, please.
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Postadresse:
D-14109 Berlin
Complexity comes for free, simplicity you have to work for.
Postadresse:
D-14109 Berlin
RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Freddie Akeroyd - UKRI STFC via Tech-talk
BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Michael Davidsaver via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS 7 & Petalinux 2019.2 Hu, Yong via Tech-talk
Next: RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Freddie Akeroyd - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Freddie Akeroyd - UKRI STFC via Tech-talk
