Writing double scalar values to a ai record works great.
I tried both aai and waveform to write array values of doubles but no success.
I am using LabView 2018 SP1. Do you have a list of what's working and what's not?
Best,
Jalal
Jalal,
Can your labview write scalar values (e.g. to a longin record ) to your softioc?
Have you tried writing your labview array to a waveform record on the softioc?
Using earlier versions of the NI EPICS software, I seem to recall there were some data types that wouldn't work (I think double was OK). I haven't tried the 2020 version but glad to see it has been updated.
-ps
On Tue, May 26, 2020 at 3:18 PM Mostafa, Jalal (IPE) via Tech-talk < [email protected]> wrote:
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using
EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
field(DTYP,"Soft Channel")
field(NELM, "10")
field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to
softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
- Re: SoftIOC and Labview Paul Sichta via Tech-talk
- SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
