1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SoftIOC and Labview
From: "Baily, Scott A via Tech-talk" <[email protected]>
Cc: "Mostafa, Jalal \(IPE\)" <[email protected]>
Date: Wed, 27 May 2020 17:04:30 +0000
If you’re writing a LabVIEW client application CALab sounds like the way to go.
If the goal is to serve data via EPICS, then you should consider running an EPICS IOC on the machine running LabVIEW.
lvPortDriver  ( https://github.com/sbaily/lvPortDriver ) will let you do this on any OS that can run EPICS and LabVIEW.
Your LabVIEW program starts the EPICS IOC, and lvPortDriver (an asynPortDriver class with LabVIEW wrappers) handles the communication between the IOC and LabVIEW.
For more information see:  https://conference.sns.gov/event/11/contributions/33/attachments/77/236/EPICSSept2016.pdf
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Wednesday, May 27, 2020 1:36 AM
To: EPICS Tech Talk <[email protected]>
My 2cts - your mileage may vary:
The NI implementations of CA (client and server) were indeed getting better over time, but they started at a very low level of compatibility.
Their newest versions are pretty much working (at least for scalars), but - especially for their CA server - you are always in for some surprises, and your clients might need special configuration when talking to an NI Channel Access server.
I can just underline what Gabriel wrote: In my experience (which is obviously biased as I was working at BESSY for a long time), CALab is the most reliable, robust and stable CA client for LabVIEW.
(Doesn't just look better - it works better, too!)
Cheers,
~Ralph
On Wed, 27 May 2020 at 08:27, Gabriel Fedel via Tech-talk <mailto:[email protected]> wrote:
I had the same problem with older versions of Labview. As soon I know
the waveform implementation on Labview is wrong, so you shouldn't trust
on it.
An alternative is CALab
(https://www.helmholtz-berlin.de/zentrum/locations/it/software/exsteuer/calab/index_en.html),
I've tried once and it looks much better than NI solution.
Prev: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Next: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Next: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
