Subject: Re: Strange problem with areaDetector driver
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 28 May 2020 10:24:48 +0200
Hello
After some debugging, it turns out that the reason for the problem is
CS-Studio.
I have set up an opi Scene with an IntesityGraph for the Image. If I set the
Data width and Data high to zero, the scene chanes from "No data" to
"disconnected". If I set Data width to 4565 and Data height to 3520, the scene
can not be loaded and results in java.lang.IllegalArgumentException.
No further information is available. The scene can then even not get loaded
into the OPI Editor and needs to be modified in a text editor.
For other cameras I was able to set the data height and data width parameters
of the IntensityGraph to 2048 x 2048. Is there a size limit for this Widget?
I did not find any hints obn that in the documentation.
Jörn Drteyer
Am Donnerstag, 28. Mai 2020, 09:29:58 CEST schrieb Jörn Dreyer via Tech-talk:
> Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via Tech-talk:
> > > Closed the OPI screen that shows the image. Now the number of threads is
> > > constant. System load is at normal level.
> > When you saw the threads and high system load did you use top -H to see
> > whether the threads with high CPU load were CSS threads or IOC threads? I
> > suspect they are CSS threads.
> No they are all started from the IOC. After 300 threads spawned I decided to
> stop the IOC. I used
> ps -eLF | grep st.cmd | wc
> > > Will need some time to gat that going. Java on my system seems to have
> > > problem with the code.
> > ImageJ on both Linux and Windows comes with its own version of Java in the
> > ImageJ/jre directory, so it should be completely independent of your
> > system
> > version of Java.  Get the latest version of the ImageJ zip file and
> > install
> > it in your own directory so you don't need to worry about system
> > permissions, etc.
> I got it working, but there seems to be a problem that only half of the
> image is intrerpreted correctly. The ArrayType is UInt16 instead of UInt8.
> Will need to find out teh reason for that.
> Regards,
> Jörn
> > Mark
> > -----Original Message-----
> > From: Tech-talk <[email protected]> On Behalf Of Jörn Dreyer
> > via Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM
> > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
> > > Hi Jörn,
> > > > I ran into a severe problem in the image readout handler.
> > > > When calling doCallbackGenericPointer() the IOC creates every time a
> > > > couple of  new threads and consumes lot of CPU power ( 300% on a
> > > > quad core).
> > > First a few questions:
> > > Is this Linux or Windows?
> > Linux
> > > What frame rate are you using?
> > 0.5 Hz
> > > What plugins are running?
> > Only NDStdArray.
> > > Is the CS-Studio GUI on the same machine as the IOC or a different
> > > machine?
> > On the same machine
> > > The first thing to establish is whether the problem is the
> > > areaDetector IOC or the CS-Studio client.  I suggest you do the
> > > following:
> > > -  Disable all plugins except NDPluginStdArrays for testing.
> > Done,
> > > - Exit CS-Studio so there is no display client running.  What is the
> > > CPU load under those conditions?
> > > - Try the ImageJ viewer instead of CS-Studio for testing.  Does that
> > > also have the problem?
> > Regards,
> > Jörn
> > > Mark
> > > ________________________________
> > > From: Tech-talk <[email protected]> on behalf of Jörn
> > > Dreyer via Tech-talk <[email protected]> Sent: Wednesday, May 27,
> > > 2020 7:03 AM
> > > Subject: Strange problem with areaDetector driver
> > > Hello,
> > > currently I have a very strange problem in a code I'm developing to
> > > read out cameras from ZWO. I ran into a severe problem in the image
> > > readout handler. When calling doCallbackGenericPointer() the IOC creates
> > > every time a couple of new threads and consumes lot of CPU power ( 300%
> > > on a quad core). So after a very short time the system becomes
> > > unresponsive and has to be switched off. The image is 3520*4656 bytes in
> > > size and is in monochrome mode, so UInt8 as data type.
Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Prev: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Next: display builder web runtime 吴煊 via Tech-talk
Next: Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
