1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Asyn4-38 SetOption Parity "Even" fails - "Invalid argument"
From: Jan Hoppius via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 02 Jun 2020 20:23:32 +0200
Hey everyone,
I have some trouble running an Raspberry Pi IOC with serial communication in parity-mode "even".
I adapted an online example and got it running without problems as long as the asynsetOption parity in st.cmd is "none"
asynSetOption("SERIALPORT",-1,"parity","none"). I checked the communication with an oszilloscope and it is fine.
As soon as I change the parity to "even" (thats what I read from the ASYN4.38 manual) it fails.
Base is R7.0.3.1
I tried ASYN 4-36 and 4-38
I tried "even" "EVEN" and "Even"
st.cmd and log after ioc-start see below
Do I have to change the parity somewhwer else? Or are other settings colliding?
Thanks in advance, best regards, Jan
st.cmd: (parity "none" is fine, "odd" is also failing)
#!/home/pi/Apps/epics/helloWorldIOC/bin/linux-arm/helloWorldIOC
#- You may have to change helloWorldIOC to something else
#- everywhere it appears in this file
< envPaths
epicsEnvSet(STREAM_PROTOCOL_PATH,"/home/pi/Apps/epics/helloWorldIOC/helloWorldIOCApp/Db")
cd "${TOP}"
dbLoadDatabase "/home/pi/Apps/epics/helloWorldIOC/dbd/helloWorldIOC.dbd"
helloWorldIOC_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyS0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","19200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","even")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("/home/pi/Apps/epics/helloWorldIOC/db/arduino.db","PORT='SERIALPORT'")
## Load record instances
#dbLoadRecords("db/xxx.db","user=pi")
cd "${TOP}/iocBoot/${IOC}"
iocInit
## Start any sequence programs
#seq sncxxx,"user=pi"
Log after starting the IOC - Failure in Line 14.:
< envPaths
Can't open envPaths: No such file or directory
macLib: macro TOP is undefined (expanding string cd "${TOP}")
setOption failed tcsetattr failed: Invalid argument
macLib: macro TOP is undefined (expanding string cd "${TOP}/iocBoot/${IOC}")
macLib: macro IOC is undefined (expanding string cd "${TOP}/iocBoot/${IOC}")
iocInit
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built May 13 2020
epics>
Re: Asyn4-38 SetOption Parity "Even" fails - "Invalid argument" Eric Norum via Tech-talk
Re: Asyn4-38 SetOption Parity "Even" fails - "Invalid argument" Florian Feldbauer via Tech-talk
Re: Asyn4-38 SetOption Parity "Even" fails - "Invalid argument" Jan Hoppius via Tech-talk
Prev: Re: Setting an array to zero length Johnson, Andrew N. via Tech-talk
Next: Re: Asyn4-38 SetOption Parity "Even" fails - "Invalid argument" Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Minor issues building base 7.0.4 on Windows Michael Davidsaver via Tech-talk
