Subject: Re: EPICS_BASE smart definition
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: Touchard Dominique <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Jun 2020 18:09:29 +0000
Hi Dominique,
> On our site we used to have only one EPICS base with supports linked on.
> The goal is to install few EPICS releases on site with a smart approach.
> The goal is at the end, to containerise(?) each application.
Sounds like you want to pick one of these two approaches. If you
containerize your IOCs each container only needs to contain one version
of EPICS Base. If you want to upgrade, you stop the old container and
start a fresh one built with the new version of EPICS Base. (Keep the
old one around for a while in case you need to roll back.)
> EPICS_BASE:=$(shell echo ${EPICS_BASE})
A potential problem with this is that you might be modifying a file
which is under revision control. It's easy git revert this change by
accident. Ralph's CI scripts generate a RELEASE.local file which only
contains autogenerated stuff and doesn't even need to be in the checked
out source directory (it can live one level above). He simply includes
it by appending
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
to the end of the existing static RELEASE file. More and more modules
already come with these lines [1,2].
Hope that helps,
Martin
[1]
https://github.com/epics-modules/asyn/blob/master/configure/RELEASE#L19-L21
[2]
https://github.com/epics-modules/motor/blob/master/configure/RELEASE#L47-L49
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Prev: EPICS_BASE smart definition Touchard Dominique via Tech-talk
Next: Re: EPICS_BASE smart definition Ralph Lange via Tech-talk
Prev: Re: EPICS_BASE smart definition Ralph Lange via Tech-talk
Next: Re: RE: iocLogServer, logstash & procServ 吴煊 via Tech-talk
