1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: RE: iocLogServer, logstash & procServ
Date: Wed, 10 Jun 2020 11:23:14 +0800 (GMT+08:00)
Hi all,
 I quote this message as I wish to know whether the issue of logstash dropping connection has been fixed, or how is it going on now.
Best regards,
Xuan
-----原始邮件-----
发件人:"Kivel Niko (PSI) via Tech-talk" <[email protected]>
发送时间:2019-10-08 19:12:29 (星期二)
收件人: "Alfio Rizzo" <[email protected]>, "[email protected]" <[email protected]>
抄送:
主题: RE: iocLogServer, logstash & procServ
Hi Alfio
it's not an issue with logstash, the issue is in Epics base. To my best knowledge, Dirk is working on it. But, I'm not certain about the 'official' release status.
Right now we operate a fixed version of Epics base in production and I get north of 40k caPutLogs per hour w/o problems.
I use the ELK stack for syslog, caputlog and hardware monitoring through icinga2. The total index rate is about 100 /s and it's stable for weeks now.
Imho it's not a good idea to find a workaround, something as essential as logging should be properly implemented in base.
best
Niko
Paul Scherrer Institute
Dr. Niko Kivel
Forschungsstrasse 111
WBGB/014
5232 Villigen PSI
Switzerland
phone: +41 56 310 2226
email: [email protected]
From: Tech-talk [[email protected]] on behalf of Alfio Rizzo via Tech-talk [[email protected]]
Sent: Tuesday, October 08, 2019 12:21
To: [email protected]
Subject: iocLogServer, logstash & procServ
I read that maybe iocLogServer will be dismissed and that logstash has some drop connection issue.
I am using instead procServ to listen on caPutLog port running a simple infinite-loop script.
In this way caPutLog write its output to procServ logfile.
I think that procServ is good replacement for both iocLogServer and logstah, unless there are some advantages that the others have.
@Ralph, is there any option to make procServ to listen forever without the need to run any command (e.g. my infinite loop script)?
Best
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
Re: iocLogServer, logstash & procServ Johnson, Andrew N. via Tech-talk
Prev: Re: weird record names? Hu, Yong via Tech-talk
Next: Re: weird record names? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: EPICS_BASE smart definition Konrad, Martin via Tech-talk
Next: Re: iocLogServer, logstash & procServ Johnson, Andrew N. via Tech-talk
